I'm working on some HT main speakers using the Peerless 850122 midwoofer and the Seas 27TFFC tweeter in a sealed box.
My starting point was Jason Andreason's reflex mini monitor which features the two drivers I'm interested in using. http://www.kaiaudio.com/diy2001/jasonopen.html My query concerns the crossover and baffle step. Since I'm changing the enclosure dimensions (to a 10" wide baffle), I take it I'll have to change the baffle step component values. How do I calculate this, and would I have to change any other values in the crossover due to the change in enclosure shape and volume? Thanks in advance, Glenn |
#2 |
http://www.speakerbuilder.net/web_fi...eek/Totfr1.jpg
Some useful info here and probably a better crossover. Baffle step correction is via Rbs and Lbs - very crude, and it appears to only offer around 2dB of baffle step correction. The SB network is for an 8.5" baffle, so 10" is 18% more, IMO probably the effect would be slightly richer voicing. I'd use the SB network as it is, with adjustment of the 3.5R tweeter resistor to taste for the 27TFFC. |
#3 |
Thanks sreten. I had looked at the SB site a while ago, but didn't think of substituting the 27tffc tweeter.
http://www.speakerbuilder.net/web_fi...k/pcrkmain.htm The baffle width is no problem. I can change my enclosure dimensions to suit. Thanks again, Glenn |
#4 |
A series filter, although for a floorstander can be found at:
http://www.geocities.com/rbrines1/Pa...less_Pipe.html He states that the filter suits Seas 27tffc. http://www.geocities.com/rbrines1/im...R_XO_small.gif |
| FS: Peerless 830875 and SEAS H881 | cs | Swap Meet | 0 | 12th November 2008 12:07 PM |
| Peerless 830875 vs SEAS CA18RNX | cs | Multi-Way | 0 | 5th March 2008 11:51 AM |
| Peerless HDS 134 or Seas M15CH001 Hexadym | stimpies | Multi-Way | 2 | 6th September 2005 01:49 AM |
| Seas Standard line? Peerless HDS? | michael | Multi-Way | 86 | 22nd April 2004 11:57 PM |
| Peerless/Seas russian 2-way | JC Fardo | Multi-Way | 7 | 24th January 2003 10:25 AM |
| Page generated in 0.10668 seconds (65.66% PHP - 34.34% MySQL) with 10 queries |
