Every year I seem to be looking for some 6" flared ports.
It's that time of year to ask again, has anyone found any yet ? <don't want to use two 4" flared ports> |
#2 |
the obvious question is why not ?
Flaring allows smaller diameters than what would seem appropriate, but by the time you get to 6" diameter generally port velocity issues are not an issue, so a 6" flared port is unlikely to be sensible. AFAIK a 4" flared port is ~ = a 6" plain port. So a 6" flared port = 9" plain - never ever seen one. |
#3 |
It does exist, the link below takes you to a norwegian shop who sells 3", 4" and 6" flared ports. Unfortunately I don't know where you can get them in your country.
Frode 6" flared ports |
#4 |
Well my Norwegian is zero at best, but as far as I can tell
the inner diameter of the flared ports is 103mm = 4". |
#5 | |
Anyway, the box would have to be large, or fh high, if the tube is not to be very long. |
#6 |
Why would you want to buy 6 inch flared ports?
If you really want them, Make it my friend! You can get your potters table out and have it made from clay! Its been done, They sound quite nice too, but they need to be thick, Or get a 6 inch drain gutter made from PVC plastic, heat the throat of the pipe, slowly! Then press down with a plate or bowl and that will give you the flare you want. Or just get a Exhaust maker to shape a metal trumpet for you. This is a little Blue Peter but its fun. If you do make it please post a picture |
#7 |
The Aeroport seems to be the only commerical offering,
but last year the company said they didn't offer the 6" size anymore. I could use two 4" flare ports, but the flare size is 7" and I don't have 14" of space so I wanted a single 6" flared port. I will need 6 ports for six 15" woofers. One 4" flared port created too much port noise for my liking. I'm trying to get the best sound quality and need a larger port. Worse case I would have to use 6" plastic pipe and make some flare ends out of wood using a router to create a small flare. I can't find 6" pipe at the hardware store or home improvement centers. <-- hehe |
#8 |
Make them!!!
I've been doing them for ten years ever since there was an article in the JAES about their positive benefits. It's not that hard Mark
Mark |
#9 | |
Woofer size and box size and what kind of sound do you get from a 6 inch port? |
#10 | |
diyAudio Moderator Emeritus
Another possibility is a rectangular port.
Rodd Yamashita |
| Making Flared Ports | CBFryman | Subwoofers | 14 | 21st September 2006 09:52 PM |
| Flared Ports Part 2 | Collo | Subwoofers | 23 | 5th April 2006 06:37 PM |
| Flared ports and turbulence | Collo | Subwoofers | 59 | 21st November 2005 10:17 AM |
| For those interested in flared ports... | f4ier | Multi-Way | 0 | 26th May 2002 03:47 PM |
| Page generated in 0.18994 seconds (50.21% PHP - 49.79% MySQL) with 10 queries |
