What sources do you folks know for subwoofer plate amps that have a lowpass filter with 24dB per octave lowpass filters?
Davy Jones |
#2 |
I typed:
plate amp 24db into Google and got some results. |
#3 |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 | |
PartsExpress has a couple of less expensive ones that have a 24db lowpass - 300-802 and 300-804. The 804 (200 watts @4 ohms) has "soft clipping;" The other, one (100 watts) does not.
Davy Jones |
#5 |
here's one using an LM3875 as the amplifier (note -- I didn't draw in the 0.7uH inductor across the 10Ohm output resistor) -- the filter values are set for 400Hz -- each filter Q is 0.707 -- the first opamp is just a buffer, the second provides 50uS of compensation (which you can adjust) -- use Texas Instruments Filter Pro for the F3 point you need:
#6 |
Rythmik Audio sells one. They have a web site. Ive seen other vendors sell thier products as well.
| Plate Current VS Plate Voltage Graphs | Captn Dave | Tubes / Valves | 2 | 13th February 2009 08:57 PM |
| ECC83 - Long Plate vs Short Plate | poynton | Tubes / Valves | 16 | 17th February 2008 07:42 AM |
| 2a3, single plate-double plate? | tenderland | Tubes / Valves | 5 | 30th October 2005 09:03 AM |
| Subwoofer Plate Amplifier Base Plate supplier? | jwells777 | Parts | 1 | 11th May 2003 07:40 AM |
| Page generated in 0.13051 seconds (63.66% PHP - 36.34% MySQL) with 11 queries |
