Distance of port to back wall?
Old 10th June 2004, 01:06 AM   #1
mitch808 is offline mitch808  United States
Default Distance of port to back wall?
Is ~3" an adequate distance from the back wall of my sub box to the port?
TIA
Mitch
Old 10th June 2004, 02:49 AM   #2
454Casull is offline 454Casull  Canada
What's the target SPL, and is the port flared?
Old 10th June 2004, 04:39 AM   #3
I didn't plan on using a flared port, although I gather it would help immensly.
But I'm shooting for about a F3 of 19Hz, at around 109db.
Old 10th June 2004, 08:30 AM   #4
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
As a general rule, I would leave at least one port dia. distance away from the back wall. If you port dia. is 4", leave at least 4" from the wall.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 10th June 2004, 01:59 PM   #5
markp is offline markp  United States
I leave three times the port size from the wall or it will continue to act as one large port of an unknown legth.
If it sounds good... it is good!
Old 10th June 2004, 04:40 PM   #6
I would use more distance then, just to be on the safe side.
Old 10th June 2004, 05:13 PM   #7
roddyama is offline roddyama  United States
roddyama's Avatar
In a quick search, a number of manufacturers suggest placement similar to Vikash at about one port diameter. I must admit that, intuitively, this seems wrong to me. Particularly considering the air velocity for 109db @ 19Hz in a 3" port will approach 30ft/sec. (this is also an argument that velocity and not acceleration is more directly responsible for SPL, but that's a different discussion.)
I think I would consider a larger port if possible.
I would be very interested to hear an explenation on how you can place the port so close to a wall and not adversely affect its output.
Rodd Yamashita
Old 10th June 2004, 05:26 PM   #8
diyAudio Member RIP
The critical distance is when the the CSA of the port
circumference to the wall = the CSA of the port.
This occurs when the spacing is 1/4 of the port diameter.
So I agree with Vikash, and have to disagree with MarkP.
And to answer Roddyama's query with a spacing of 1 port
diameter away from the wall the acoustic impedance change
at the exit of the port is only slightly affected.
Note that there is a huge change in air velocity at the exit.
sreten.
Old 10th June 2004, 07:00 PM   #9
roddyama's Avatar
sreten.
Yes, I can see the where the air velocity would change dramatically at the port exit (essentially a half space). What it seems you should get is the loading on the port of a conical horn that is expanding at the rate of 2pi X distance from the ports center.
Rodd Yamashita
Old 10th June 2004, 07:51 PM   #10
diyAudio Member RIP
Well its only 2pi for half effective baffle width, after that its 4pi,
given free space. For close to wall its ~ 2pi above baffle width.
sreten.
Distance of port to back wall?Hide this!Advertise here!
Uneven distance from back wall? Lewis Moon Multi-Way 0 5th October 2008 10:12 PM
dipole midrange or subwoofer, distance with wall ? mbon Multi-Way 34 2nd August 2004 06:26 AM
Copyright ©1999-2017 diyAudio
