Black hole? - Page 3 - diyAudio
Old 11th June 2004, 07:21 PM   #21
NH7RO is offline NH7RO  United States
Default BHO
KT, that is correct. BH Offset is one of the Thiele & Not-So-Small Parameters...
Old 11th June 2004, 08:02 PM   #22
usekgb is offline usekgb  United States
usekgb's Avatar
Originally posted by Nappylady
BRILLIANT!!
I've been struggling with that notion for a while... whether it's possible or not to get time and phase alignment by moving signals backwards in time... by implementing this in my PA system, I'll be able to have correct time alignment without a delay, so I will hear more accurately what's going on!
Thanks so much!
Anyone know a supplier of black holes and flux capacitors? I searched at Parts Express and couldn't find any....
Have you tried Ra-Elco Nappy? That place seems like a perfect place to find a black hole.
Zach
Ahhhhhhhhh...............That's what that button does.
Old 11th June 2004, 11:10 PM   #23
Rocky is offline Rocky  Norway
Rocky's Avatar
These people claim to join electrons in audio signal lines into "much more stable electronpairs" (getit? ) using quantum purifying, I guess that's the perfect place to request small black holes to replace your alnico magnets for that 300dB/W/m sensitivity...? They probably have the technology to do so.
Old 12th June 2004, 10:47 AM   #24
pinkmouse's Avatar
Hey, if we have a small black hole in the box, we can forget the magnet and coil assembly. All that's needed is a small weight fixed to the back of the cone that can be driven directly by modulated gravity waves.
In fact, if we use a sufficiently small black hole, that will give a well defined gravity gradient that could be used to affect a space/time phase change discontinuity, thus replacing the intrinsically faulty cone with a pure anomaly. This should reduce many resonance problems, but some sheilding might be required for the excess of gamma radiation produced.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 12th June 2004, 11:26 AM   #25
Mudge is offline Mudge  United Kingdom
The only problem is the smaller the black hole, the quicker it evaporates, so you'd need quite a big one in order to make it work for any lengthy period of time.
Mark
The king of all that is evil has left the building
Electronic hobbiest's black hole Frazzled Equipment & Tools 39 26th April 2007 03:11 PM
What to do when your hole is a bit big? tommytube Multi-Way 6 13th September 2005 02:08 PM
help...drilled hole too big ultrachrome Parts 16 15th April 2003 04:07 PM
Copyright 1999-2017 diyAudio
