Old 8th June 2004, 05:10 AM   #1
Default Tang Band W3-532S vs 871's
Anyone out there familiar with these drivers. I have 16 of them that I am finally getting around to doing something with. I was thinking of a mini line array with 8 per side on a winged open baffle and some PT2's.
I see everyone talk about the 871's, but never any mention of this model. It is the one with the neo magnet so it has a very small profile which looks nice in terms of rearward radiation.
Thanks guys.....Greg
Old 8th June 2004, 07:06 AM   #2
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
It does look like it would breath a little better in the back vs the 871 . I don't really care for PPM cones, but OB should help them sound more natural. They'll be pretty from the front or the back. I hope they sound as good as they look.
Everyone has a photographic memory. It's just that most are out of film.
Old 10th June 2004, 03:13 AM   #3
MarkMcK is offline MarkMcK  United States
I have tested a number of the 532 drivers. Like the paper 871, they have a large spike in the output around 17 to 18 kHz caused by cone breakup. Other TB 3 inch PPM drivers (2 inch cones) that have a shallower basket and a shorter voice coil former do not suffer from this high frequency problem. The 532 also shows a lot of driver to driver variability. It would be worth your time and effort to try matching drivers for both side to side balance and for selecting position in the array.
I have an AudioXpress article scheduled for publication later this year that will go into more detail on the TB PPM problems and some simple solutions. I have a picture of one of my modified 881S cones in the system picture thread. Many of those modifications will also help the 532. If you e-mail me and promise not to share I will reply with more details of specific modifications for the 532.
Best of luck,
Mark
Old 10th June 2004, 07:33 AM   #4
Hybrid fourdoor's Avatar
Thats interesting that you mention the output fluctuation. In the 881S's that I used one speaker is slightly louder than the other. I only have to adjust the balance a couple clicks, but I wondered what it was all about
I enjoy my organic shapes.....
Old 10th June 2004, 06:15 PM   #5
what does PPM stand for anyway?
Old 10th June 2004, 10:35 PM   #6
Poly Propylene Molded??? Their kinda translucent. If you had a light in the enclosure it would shine through the cone pretty easy.
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
Tang Band 8" sub Qts Dave Jones Subwoofers 2 2nd June 2004 11:53 PM
Page generated in 0.52987 seconds (17.79% PHP - 82.21% MySQL) with 10 queries
