All done!
Previously I had finished a set of Ariels that a man abandoned, but this is the first loudspeaker system I have designed (with LOTS of help from the folks here) and built. Except that the cabinets are still raw MDF, it's finished. I know everyone who builds a set of speakers says this, but -- golly they sound great! The last tweak was to change out two resistors in the Parts Express plate amp, to change the boost to +3 db at 19 Hz. That was not as easy as the instructions would lead you to believe. The hard part was removing the preamp. It was glued around the edges to a rubber gasket about 1/2" thick. There was not sufficient room to get a knife all the way around to cut it loose. I tore up the rubber a little getting the thing off, but some Shoe Goo (tm) set that right. I'm also running it with a Richter Scale Series Three. I changed the crossover in it to 72 Hz by swapping out resistors. The bass now integrates perfectly, and it's solid to below 20 Hz. The final version of the BSC circuit is 2.75mH/5Ohm. The box for the mains is made from 3/4" particle board throughout. Inside dimensions are H 15 1/4", W 4", D 5 1/4". There is a 1" diameter hole (vent) near the bottom front of the box. The MDF itself forms a 3/4" long port. The speaker is mounted 6" from the top (ID). There's a terminal cup from Madisound on the back of each. The top part of the cabinet is lined with 1/4" felt. Each box is lightly stuffed with poly fiber, from top to about three inches below the driver. The driver cones were coated with three thin coats of dammar varnish, and painted with a thin coat of ivory black artists' oil paint thinned slightly with dammar varnish. The box for the sub is made of 1" MDF. Inside dimensions are H 24", W 11", D 6.75". There is a 1" board with large holes in it half way up and parallel to the floor -- a "shelf brace". I guess that after subtracting for the driver, passive radiator, amp, and shelf brace, the internal volume is about 26.5 liters. That yields an alignment with an "extended bass shelf." The top of the box contains the driver and the bottom contains the passive radiator (400 grams). The plate amp is from Parts Express, and has been modified to have 3db boost at 19 Hz. Oh -- I put some of those spikey feet on the bottom. Someone here recently said that wasn't a great idea. I might try removing them. I am using a Linkwitz-Riley 24db/octave crossover at 72Hz. If you use the crossover that's built into the sub amp, a somewhat lower setting would probably be better. That's it.
Davy Jones |
#2 |
How do they compare to your ariels? How much difference did the dammar make (I'm assuming it was the 107 that you dammarred). Have you tried putting in a phase plug? I've heard this can help quite a bit... Does the 107 really go solid to 72hz? I've been thinking recently about trying a 108ez with a helper woofer comming in at about 150~200hz... so I'm quite curious about your exprience.
Joe |
#3 | |||||
In theory, if the mains were down 3db and the Linkwitz-Riley crossover on the sub put it down 6db at 72 Hz, I should have a small dip there. But in fact there appears to be small peak (in my listening room at least). I don't know why, and I don't know if it's worth investigating. It sounds real good the way it is. Quote:
Davy Jones |
#4 | |
http://www.alegriaaudio.com/bipole_voigt_pipe.htm planet10 sells phase plugs on ebay. http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW |
#5 | |
Davy Jones |
#6 |
I suppose the Mms would actually lower since you're removing the dust cap and the plug attaches to the pole piece. Even so, it's so little I doubt that parameter changes.
#7 |
By removing the dustcap and changing the air loading, Qts goes down slightly, improving transient response, though whether it's enough to be audible is very driver/design dependent. What is audible though is that a properly designed plug improves dispersion (power response) and eliminates the comb filtering that occurs due to keeping eigenmodes from developing across the diaphragm.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 |
The FE103 should run into x-max limitation at very low volumes if used as low as 72hz without loading. I've tried the fe87 in a MTM with two Seas L15rly crossed at 500hz (4:th order LR). I found my fe87's to be a bit shouty and not as clean as the L15 crossed to scan-speak 9300 at 2khz. Dammar might help here, what did you use? Also, my box was only for testing, no fancy interior shapes, just a small 2L square box with some standard damping for the fe87. Do you think the fe's are sensitive in this regard? /Jesper |
#9 | |
#10 | |
So, I take it I could just try the phase-plugged speaker in the same boxes, and not be guaranteed to fail, eh?
Davy Jones |
| Peerless HDS Exclusive 6"5 or 8" ? | youyoung21147 | Multi-Way | 23 | 7th May 2010 06:06 PM |
| Peerless 850146 "replacement" 830668 | fat_terry | Multi-Way | 13 | 24th January 2007 03:03 AM |
| FS: (1) used Peerless XLS 12" | StriatedFoot | Swap Meet | 3 | 29th December 2006 07:18 AM |
| Peerless XXLS 12" DVC (830837)- replacement for PE Dayton 12" DVC 295-185? | tktran | Subwoofers | 2 | 14th August 2005 02:04 PM |
| FE107e prototypes done! 10" XLS next | Dave Jones | Full Range | 8 | 26th May 2004 11:38 AM |
| Page generated in 0.81656 seconds (15.55% PHP - 84.45% MySQL) with 11 queries |
