Old 7th June 2004, 01:02 AM   #1
rnoble is offline rnoble  Australia
Default Long binding posts for Sonotube (AUS)
I'm in the middle of building my sonotube sub which has a baffle thickness of 36mm. The speaker is down firing and the terminals will be mounted on the baffle. As such I need some really long speaker terminals to be able to get through this thickness. I don't necessarily need them 36mm+ but regular ones are just too short, the longer the better.
I realise that partsxpress have them but they are a long way away from Melbourne Australia and paying $20us postage for a few nuts and bolts seems extravagent to say the least. So, to my question, does anyone know of a supplier of reasonably long binding posts somewhere in Australia?
Thanks in advance
Rod
Old 7th June 2004, 08:02 PM   #2
DC Dave is offline DC Dave  United States
DC Dave's Avatar
Just an idea...
You could use a drill or router to create blind holes 10 or 20 mm deep for a normal length binding post to mount in.
If you are using banana plugs you can mount them the opposite way as shown in the picture and they would be flush with the baffle for a clean look. Or you can make a bigger single recess instead of two individual holes.
Old 7th June 2004, 09:28 PM   #3
BobEllis's Avatar
or make your own with brass bolts of suitable length and wingnuts.
Old 8th June 2004, 06:07 PM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Have a look at Altronics in WA, cat no P2004 and P2005 at AU$4.50ea. These are 32mm and with a little bit of countersinking should do the job.
http://www.altronics.com.au/cat.asp?...p=155&id=P2004
Old 9th June 2004, 05:26 AM   #5
Thanks very much for the input, I was considering counter sinking brass bolts but that Altronics site looks like the go!
Old 9th June 2004, 06:43 AM   #6
Ap is offline Ap
Ap's Avatar
An alternative method:
Make a large cut-out in your baffle, make a smaller plate (use 4-5mm plastic or steel) larger than your cut-out.
Mount your regular bananas on the small plate, mount the small plate on your baffle.
Old 9th June 2004, 06:55 AM   #7
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Long binding posts for Sonotube (AUS)
Extreme speaker connectors
/Per-Anders (my first name) or P-A as my friends call me
Old 9th June 2004, 09:29 PM   #8
That one came up on a search Peranders but the link is broken.
Old 9th June 2004, 09:35 PM   #9
peranders's Avatar
Check here
http://www.ruhstrat.com/en/rh_klem/index.cfm
Note also that they aren't high-end stuff. They are for heavy industrial use. Have you seen any bigger mamas? 400 grams binding post i pure copper
binding posts h_a Parts 21 12th January 2009 11:10 PM
FS:GOLD PLATED SPEAKER BINDING POSTS LONG Amplifier - FREE SHIPPING! YFW Vendor's Bazaar 0 29th August 2008 02:45 PM
WTB: Long binding posts spudfrog Swap Meet 5 13th September 2007 01:54 PM
Page generated in 0.14235 seconds (60.58% PHP - 39.42% MySQL) with 11 queries
