PHL woofers!!!!
Hi
The tad 1102 van be used at 1200 cycle proberbly. The 1201 not higher than 1000 cycle IMO.
Sure, the 15" can be used with great dispersion at 400-500 cycle
Well, regarding 150 cycle-2000 is a tough one. It's possebly, but not recommended.
1. 150 cycle is very deep and you need a very large horn for a compression driver.
2. This large horn will then lack in higher freq.
I would say 300-2000 is possebly. There are many choices. JBL 2440, 2482, ALE, Goto, WE, RCA, Emilar and lately my fave has been the Selenium D4400TI. I've not heard this driver, but I think it has the most perfect measure for midrange I've ever seen. The driver does not try to play more than possebly, which give you perfect graph. It has perfect midrange curves. Check out at Parts Connection. Only 298 usd each.
Tadman
