Horn vs Open baffle bass
Old 2nd April 2005, 07:44 AM   #191
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Can you describe each buffer??
I wasn't thinking of specific buffers here Richard. Rather building different ones and choosing the best for each job.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 2nd April 2005, 08:47 AM   #192
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
Default Re: Short bass horns
Originally posted by Matjaz
What do You thing about new Avantgarde Audio Meta Duo? Did somebody had chance to heard them? It looks that they somehow brake the rules with published data.
Rgds,
Matjaz
http://www.avantgarde-acoustic.de/ne...rache=en&id=53
Firstly,I dont see data.
With a total of 8 12" bass drivers and insignificant basshorn volume I would expect direct radiator loading at bass frequencies,not significant horn loading.
Old 2nd April 2005, 01:08 PM   #193
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Default Re: Re: Short bass horns
Horn loading or not on those bass sections, they sure do look good. If they sound half as good as they look, who cares about the horn. With 4 12's per side you probably don't need it.
Everyone has a photographic memory. It's just that most are out of film.
Old 1st January 2017, 03:15 AM   #194
youknowyou is offline youknowyou  Canada
youknowyou's Avatar
the "you are there" vs "they are here" is something very interesting to me
my harbeth p3esr + sub or atc scm7 v3, in my treated room really sounds more like "they are here"
my jbl lsr32 in my untreated living room is clearly more the "you are there". personally, I prefer the "they are here"
Dad's speakers: Amphion one18/ Genelec 1037b/ ESL57/ JBL LSR32/ JBL 4430/ Tannoy RED 15 inch/
Mine: Tannoy Berkeley/Harbeth SHL5+
Old 1st January 2017, 10:11 AM   #195
Coolin is offline Coolin  Netherlands
Coolin's Avatar
Default Reflections
Imo reflections are the mayor reason that reduce the "they are here" experience
Reflections are also inside the speakers.. These can be tamed to a large degree. Opeb baffles are dipole so always out of phase. Placing far away from the rear wall helps but youd almost have to devide your room in two....
Old 22nd August 2017, 06:00 PM   #196
SoundRight is offline SoundRight  United Kingdom
Default Cardioid
Haven't read all the posts but real world size horns are monopoles at very low frequency. They become increasingly directional as mouth size increases and frequency rises.
You could put two horns back to back, reverse polarity to the rear one and add delay for full cardioid performance.
Actually has any one done that or should I patent it now!!
Old 22nd August 2017, 06:13 PM   #197
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Depends on the reflections. With the right delay and dispersion the opposite can be true
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 23rd August 2017, 01:14 AM   #198
Pano is offline Pano  United States
Pano's Avatar
Having had a listening room (lava cave) that was hypo-echoic thru the audio bandwidth, the Here/There thing became completely recording dependent. Sometimes it was even both in the same recording. For example a close mic'd singer in front of a large orchestra could be both "here" for the singer and "there" for the orchestra.
Once the room really isn't fighting you, it's amazing you'll find in the recordings. Or sometimes disappointing.
Take the Speaker Voltage Test!
Horn vs Open baffle bassHide this!Advertise here!
Open baffle bass behaviour Klimon Full Range 9 29th December 2006 04:10 PM
open baffle bass-dipole-what amp felixx Multi-Way 20 13th December 2006 07:53 AM
amp for bass open baffle felixx Pass Labs 4 12th December 2006 08:59 PM
Which driver for open baffle bass??? loudandclear Subwoofers 2 18th December 2005 06:07 AM
Copyright ©1999-2017 diyAudio
