Old 5th June 2004, 11:58 PM   #1
Question Audax bextrene drive unit replacements
I have a pair of old Audiomaster MLS1 speakers, which I'm rather fond of. One of the bass drivers recently got overheated due to an amplifier failure and whilst it still works, I'm concerned it may fail soon - or at least be partially damaged.
Does anyone out there know where I might find a replacement drive unit (or better still, a pair) - they're an Audax bextrene cone type, marked HD17B25J (about 16.5 cm outside diameter).
Or is there somewhere which can repair these drive units (the cone and surround appear undamaged).
Thanks in advance & best regards
Mike
Old 6th June 2004, 10:41 AM   #2
If my memory is correct that is the smaller magnet version of
that driver, suited to sealed box loading, the larger magnet
version being suited to sealed or reflex loading.
As far as I know no modern units are particular similar.
Drop- in replacement is not a good idea, you would have to be
very lucky for it to work well, really depends on the complexity
of the crossover, if it includes EQ for the driver, treble level at
minimum would need readjusting.
However its not all bad news :
Permanent thermal damage of a drivers voice coil is
usually immediate, causing permanent failure.
If the coil has delaminated it can soldier on (possibly
making scraping noises) and the part that has come
away from the main coil will tend to overheat.
But if there appears to be no apparent damage, IMO
imminent failure is not the case, they should be fine.
As a replacement you'll be charged an arm and a leg for
the drivers, however if you can find it on Ebay or similar
it should be very cheap.
Repairing the coil is not an option.
sreten.
Old 6th June 2004, 01:21 PM   #3
Sreten, many for the reply and for the reassuring and valuable advice.
Your comments about repairs confirm what I'd suspected -- that is, the best thing would be to watch out on Ebay (etc) for replacement drivers, or even for a pair of the MLS1 speakers; I don't think they fetch that much money and as you say, compared to a re-build or NOS driver....
Thanks again
Mike
Old 6th June 2004, 04:01 PM   #4
Thanks again
Mike
Well as far as I know Audiomaster were an offshoot of a London
retailer (K.J. Sound ?) and amost completely unknown, so they
do go very cheap, and they were not expensive to start with.
The larger MLS3 (I think?), reflex Audax 8"/Audax 1" was well
rated, at the time a Spendor BC1 ish speaker on the cheap,
worth seeking out for a "classic" British balance.
sreten.
Old 6th June 2004, 04:48 PM   #5
Bill Fitzpatrick's Avatar
That driver you are looking for sounds familiar. I think I may have one or two in the garage. I'll check later today.
Old 6th June 2004, 10:48 PM   #6
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Falcon used to carry HD Audaxes in the old times...drop them a line
Old 7th June 2004, 06:10 PM   #7
Dave S is offline Dave S  United Kingdom
Hi Mike,
Just came across this in HIFI World:
www.wembleyloudspeaker.com
Try the repair and restoration link.
Cheers
Dave
Old 19th June 2004, 10:47 PM   #8
My Italian isn't so good, but the GOOGLE translator took a shot at this:
http://translate.google.com/translat...UTF-8%26sa%3DG
The website has a list of Audax bextrene drivers of the correct vintage and part number. Perhaps he has NOS or has methods to repair them; some of the faqs suggest this is what is provided as a service.
MT
Looking for Audax bextrene driver for Tangent RS6 dcanuck Multi-Way 4 2nd November 2011 11:30 PM
Classic Audax Bextrene Units from 80s Mikett Multi-Way 6 3rd March 2010 05:31 PM
Drive Unit Repair! Brainticket Multi-Way 3 11th July 2007 07:54 PM
Speaker drive unit repair PSXmad2 Multi-Way 1 14th December 2006 12:26 AM
Linn Kaber Drive unit ANTHONY2181 Swap Meet 1 4th June 2003 02:55 PM
Page generated in 0.15641 seconds (57.68% PHP - 42.32% MySQL) with 10 queries
