My search for sonotubes end up at having to buy minimum 12 foot section (20 inch diam.) for $75.00 plus tax..only to be abe to use half of it......my next question is has anybody ever used that flexible 3/8 plywood?It goes for $40.00 per 4x8 sheet...and it looks perfect for a replacement for sonotubes..it already has a nice grain to it..or you can paint it..or better still veneer it. Does anybody see any disadvantages in using this?
#2 |
Time is money. Just think of the time and effort it will take to form the plywood tube into a perfect circle. Sonotube is done for you. You can sell the other half to someone here I'm sure. It also makes great decorative plant pot covers with some wallpaper or fabric.
If it sounds good... it is good! |
#3 |
The stuff is very flexiable...and it's about the same amount of work..you still need to cut the end circles....and once you have that you just glue this stuff around it...it looks more structual than sonotubes.......but I also see your point...thanks
#4 |
The other problem might be that if you need a 20" diameter tube then it can only be 48" tall with a 4'x8' sheet grooved along the short axis. You need 62" in circumferance for a 20" tube.
#5 |
I forgot to realize the circumfrence of 62 inch ..and since I need to construct 2 subs with it.....I would need 2 sheets....oh well back to the drawing board...thanks markp...
| Flexible Cable | Kral57 | Everything Else | 0 | 10th September 2008 06:21 PM |
| Why there are no flexible speakers? | tpsorin | Multi-Way | 15 | 15th March 2008 10:01 PM |
| Flexible wire: what is it called? | rtarbell | Parts | 4 | 2nd August 2006 08:14 PM |
| flexible wire | johngalt47 | Parts | 5 | 10th January 2005 12:35 AM |
| Looking for flexible Heatshrink | Silver Stealth | Everything Else | 0 | 19th May 2002 12:06 PM |
| Page generated in 0.22897 seconds (30.21% PHP - 69.79% MySQL) with 10 queries |
