Old 5th June 2004, 02:22 PM   #1
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Default Anything wrong with Bass on top?
I'm about to start a floor to ceiling array project. Typically bass drivers are on the bottom, I guess for cabinet stability. I'm thinking of putting the bass drivers on top, since stability won't be an issue. This will make for a much smaller footprint and save space, plus a tapered baffle with large dimension at the top would have an interesting and unique look. The super tweeter will still be in the middle, not down near the floor.
Is there anything wrong with this idea from a sound quality standpoint?
Everyone has a photographic memory. It's just that most are out of film.
Old 5th June 2004, 03:46 PM   #2
wigginjs's Avatar
I think that you are right in assuming that the reason bass drivers are typically found near the floor is because the mid and high drivers need to be near ear level. If you want to place it higher then that should be fine. Another thing to concider is that the fact that the bass drivers are typically located near the floor may help with the frequencies they are able to extend to, but yours being near the ceiling should have the same effect.
The Four Chairs
DIY Home Theater
Old 5th June 2004, 03:54 PM   #3
Bill Fitzpatrick's Avatar
The sound will be different. How different depends on the crossover frequency/slope and ceiling height. A ceiling located woofer will be further from the listener than a floor located woofer and this extra distance will affect the relative phase between the array and the woofer. This might cause a dip in response at the crossover freq.
Old 5th June 2004, 04:35 PM   #4
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
The output level will be lower, when placing the bass speaker in top. When the bass is placed at the bottom of the cabinet (near the floor) you gain app. +3dB higher output. If the speaker then also is placed in a corner you gain add. +3dB and so on....
Good or bad... You decide
However I see no problems in placing the bass at the top of the cabinet........
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 5th June 2004, 04:47 PM   #5
How do you come to that conclusion?
Old 5th June 2004, 05:29 PM   #6
RyanC is offline RyanC  United States
The output will be lower because of the lack of a boundry like the floor wich will boost as much as 6dB down low <100hz- Unless the woofer was never going to be that close to the floor in the first place.
Also my undrsanting is that higher frequencies tend to not want to cross the path of lower frequencies, so you will be limiting the upward dispersion of the tweeter or upper midrange- so if you do do that make sure the tweeter is at ear level- otherwise it would be hard to get enough HF at the listening position. that is why MTM's should be setup with the tweeter at ear level- because the M's will limit the amount of tweeter dispersion higher up- Of course the tweeter should always be pretty much at ear level unless you are using it's off axis response on purpose.- Just some thoughts,
Ryan
Old 5th June 2004, 06:23 PM   #7
It's a bit unnerving to hear timpanis, string basses, pianos etc. above your head, but if you like that stuff, go for it.
Old 5th June 2004, 06:28 PM   #8
netgeek is offline netgeek  United States
If you're talking about really low bass (i.e. < 150 Hz or so) - it shouldn't make any difference, right? But it might look pretty weird....
Old 5th June 2004, 09:37 PM   #9
Ryan
JohninCR said that it will be a floor to ceiling array thereby implying that the woofer would be at the ceiling and thereby have use of the boundary.
Your understanding about high frequencies tending toward being unable to cross low frequencies is in error.
Old 5th June 2004, 10:28 PM   #10
markp is offline markp  United States
. Also my undrsanting is that higher frequencies tend to not want to cross the path of lower frequencies, so you will be limiting the upward dispersion of the tweeter or upper midrange- so if you do do that make sure the tweeter is at ear level- otherwise it would be hard to get enough HF at the listening position. that is why MTM's should be setup with the tweeter at ear level- because the M's will limit the amount of tweeter dispersion higher up- Of course the tweeter should always be pretty much at ear level unless you are using it's off axis response on purpose.- Just some thoughts,
Ryan
The reason is that higher frequencies are very easy to locate the source of and also tweeters are usually very directional. If they are low then it will appear that the sound is coming out of the floor! Unless they are angled properly upward. Low frequencies are less directional and the location of a sub is hard to point to while listening. High and low freqs can cross at will and do cross constantly, there is no truth to that idea in practice.
If it sounds good... it is good!
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
What went wrong with my amp? Bass driver strange movement. chengs Tubes / Valves 10 20th October 2006 02:19 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
bass is in the wrong room.... SkinnyBoy Everything Else 2 29th January 2004 03:45 AM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Page generated in 0.29114 seconds (36.15% PHP - 63.85% MySQL) with 10 queries
