Old 4th June 2004, 08:04 PM   #1
Ignite is offline Ignite  Canada
Send a message via ICQ to Ignite
Default TangBand w3-871S 2-way bookshelfs
I'm working out a design for a set of 2-way bookshelf speakers using the tb W3-871S 3" full ranges. I'm looking for a 6-8" woofer to fill in the bottom end.
I'm not really interested in super-high-volume or ridiculous wall-shaking bass.
I do, however, like the sound of speakers with low extension but above all I want a woofer capable of matching the excellent sonic quality of the tb 3" drivers.
I'd like to cross the driver as low as possible but high enough to prevent the 3" drivers from being driven beyond xmax at a reasonable listening level. (150-400Hz)
The TangBand W6-1139SC 6.5" woofer from Parts Express seems interesting to me. Tuned to 30hz in a ported .6cu ft enclosure looks like there would be usable output almost down to 30Hz! That would be amazingly full range for such a small package. I'm concerned about the sound quality possible out of a 6.5" woofer with 11.5m xmax, though.
Suggestions? I don't really want to spend more then $60 USD / woofer.
Old 4th June 2004, 08:17 PM   #2
joensd is offline joensd  Germany
Woofer (not sub) to go with the W3-871S
Old 4th June 2004, 08:45 PM   #3
I was searching for quite some time. I don't know how I missed that. Thanks
Old 4th June 2004, 10:47 PM   #4
Timn8ter's Avatar
The W5's are quite nice. I used two of them in a TL and got decent results.
Sub for Tangband W3-871S ? Kees Subwoofers 1 23rd March 2008 08:20 PM
is the Tangband W3-871 the same as W3-871S michelevit Full Range 11 6th December 2006 07:09 AM
Tangband W3-871S in the UK ? jives11 Full Range 3 15th May 2006 08:43 PM
Tangband W3-871S wim Full Range 5 8th November 2005 03:50 PM
TangBand W3-871S Jye Multi-Way 47 27th July 2004 06:07 AM
Page generated in 0.10807 seconds (59.72% PHP - 40.28% MySQL) with 10 queries
