Old 4th June 2004, 03:24 PM   #1
Matttcattt's Avatar
Default Plate amps in the UK
What is the best (read: cheapest) place to buy plate amps in the UK? online shops preferable.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 4th June 2004, 04:14 PM   #2
5th element's Avatar
Im not sure, both bkelectronics www.bkelec.com and wilmslow audio www.wilmslow-audio.co.uk both sell sub plate amps. Ive just had a quick look see at bk and they have a nice 500 watts into 4ohm for about £220. I dont know if you consider that cheap but its certainly good watts per pound and will certainly have the furnature rattling. They also do a 100 watts into 8ohm plate amp at £120, which again is quiet good value for money, however if it were me and I had the money id rather pay for the big beast amp, the increase up in watts only adds a few pounds on each time so you get quite a bit more bang for buck the more watts you get.
What is the plate amp for exactly? drivers you have in mind etc.
Oh BTW wilmslow sell the same plate amps as BK, wilmslow are significantly more expensive.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 4th June 2004, 05:08 PM   #3
stee-b is offline stee-b  United Kingdom
Try CPC here :- http://custom1.farnell.com/cpc/categ...Modules&Page=1
HTH Steve
Old 4th June 2004, 08:11 PM   #4
http://custom1.farnell.com/cpc/produ...ct%5Fid=260654
is very good value, I've not seen better.
sreten.
Old 5th June 2004, 11:04 AM   #5
Matttcattt's Avatar
This would be for my current Eminence Beta 15 sub, which I am hoping to upgrade to an Adire Tempest sometime. The bridge/parrallel gainclone I have powering it at the moment is badly built (by me) and I am sick of having to fiddle with it when I just want to listen to some music.
Thanks for the links.
HTH Steve
Thanks.
sreten.
I though so to, looking at it.
Thanks.
O Audio plate amps quickshift Subwoofers 15 14th September 2008 07:48 AM
Help with some plate amps mazeroth Solid State 1 14th September 2008 12:31 AM
Woofers & plate amps audiokinesis Swap Meet 9 11th September 2008 12:17 PM
Plate amps? Enzo Solid State 6 29th January 2005 12:31 AM
Sub plate-amps in the UK CaRRiT Subwoofers 10 14th March 2002 05:35 PM
Page generated in 0.10948 seconds (66.10% PHP - 33.90% MySQL) with 10 queries
