Standing waves again...
Old 3rd June 2004, 09:54 PM   #1
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Default Standing waves again...
Designing a three way with L shaped bass cab (it will be once mid and tweet cabs are inside).
How would you most effectively calculate standing waves to determine acceptable dimensions for my L shaped enclosure?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 3rd June 2004, 10:39 PM   #2
Mudge is offline Mudge  United Kingdom
Instead of an L-shape, why not make separate cabinets for the bass and the mids? I too am building a 3 way at the moment, and am using separate enclosures a la Wilson X-1 for the bass and the mid/treble. The bass enclosure is designed so that the first standing wave is above the crossover between the drivers, and the mid/treble is totally overstuffed with acoustic foam to kill any box resonances in it's operating range.
Now I have the tricky task of eliminating panel resonances
Mark
The king of all that is evil has left the building
Old 3rd June 2004, 10:51 PM   #3
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
I thought the same thing. Enclose the mid, tweets are usually sealed these days. Use the remaining volume for the woofer. I think that keeps it simpler.
Old 3rd June 2004, 10:59 PM   #4
GM is offline GM  United States
GM's Avatar
The whole cab as if it were straight for the LF BW up to the frequency where the long vertical dim. is 2x its length. For the base of the "L", its 1st eigenmode begins at 2x its longest dim.
Since it's doubtful you will find a good compromise, just concentrate on the 'pipe' as a whole and use damping material at the top, one side, and back to attenuate the higher frequency eigenmodes.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 3rd June 2004, 11:25 PM   #5
BillFitzmaurice is offline BillFitzmaurice  United States
Banned
You want to totally line the woofer section. While damping material is unnecessary below 100 Hz, above that it's hard to use too much. As was suggested go with a sealed sub-enclosure on the mid and the same for the tweeter (unless either or both has a sealed basket) and fully line the woofer section with an inch of high density polyfill.
The idea of supressing 'standing waves' is fallacious; there's really no such thing inside of a speaker cabinet. But you do want to be sure there are no reflective surfaces inside off of which midbass and higher frequencies can reflect back to the cone, which would cause response anomalies.
Standing waves again...Hide this!Advertise here!
Minimising standing waves GerhardW Multi-Way 13 2nd September 2008 07:43 PM
Standing waves, anyone willing to experiment ? jay1st Multi-Way 4 10th February 2008 01:33 AM
Low resonance and standing waves? Audist Multi-Way 3 6th November 2005 03:29 AM
Golden ratios and standing waves Vikash Multi-Way 36 27th September 2003 02:12 AM
curved enclosures/standing waves RobWells Multi-Way 8 1st August 2003 02:28 AM
Copyright ©1999-2017 diyAudio
