Old 3rd June 2004, 02:01 AM   #1
Ap is offline Ap
Ap's Avatar
Default High Qms bass driver
How much is too much, from my understanding hgih Qms driver have less mechanical damping resulting in high impedance at Fs.
They are also better at producing bass compared with low Qms drivers (better at midrange).
Is there any downside or negative to having a driver with a very high Qms, say plus 10? (Considering it is only to be used for bass duties)
Old 3rd June 2004, 03:21 AM   #2
Hybrid fourdoor's Avatar
I don't have much of an answer, but a long time ago I posted this thread, and got some answers. I'm not sure if there was a concensus
Hope it helps a little.
I enjoy my organic shapes.....
Old 3rd June 2004, 03:55 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Qms affects impedance. It is perhaps important if your amplifier is impedance sensitive, as a rise in impedance would then cause a rise in response..
As far as transient response is concerned, Qts is the important factor, as damping is a combination of Qes and Qms. For all but a few drivers, Qes is by far the most dominant in determining Qts.
Turn off your amp, tap the woofer cone. Turn the amp on and tap the cone That's electrical damping at work.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 3rd June 2004, 08:07 PM   #4
Default Re: High Qms bass driver
The simple answer is Qms cannot be too high.
You only have to worry about it if you use current drive.
sreten.
How do i wire a horn into a high power bass amp? punkrokr1701 Instruments and Amps 19 15th April 2007 09:47 AM
How high can this popular bass driver be crossed? rick57 Multi-Way 8 20th December 2004 05:33 AM
high output sub bass mart34 Subwoofers 1 13th July 2004 04:06 PM
What shoul I use if I want low bass at high SPL (PA audio disscussion) VEC7OR Multi-Way 9 3rd November 2003 04:57 AM
Bass/mid/high, are you sure? Raka Multi-Way 4 28th September 2003 04:22 PM
Page generated in 0.09226 seconds (57.26% PHP - 42.74% MySQL) with 10 queries
