Double Back Horn MTM project
Old 2nd June 2004, 11:42 PM   #1
baggystevo82 is offline baggystevo82  United Kingdom
baggystevo82's Avatar
Send a message via MSN to baggystevo82
Default Double Back Horn MTM project
Hello everyone,
I've been throwing some ideas around again today after being inspired by some Cain & Cains last night. This is what I've come up with so far anyway, using Fostex FE208EZ drivers run fullrange and a T90A supertweeter. I've developed the horns in hornresp and they seem to be fine, assuming I haven't overlooked anything. Any comments/suggestions/problems you can see would be really appreciated.
Thanks all,
Steve
Old 2nd June 2004, 11:56 PM   #2
Nappylady is offline Nappylady  United States
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
That just makes me want to build a pair...
What kind of SPL and bass entension could one expect from such a beast?
Old 3rd June 2004, 12:10 AM   #3
Well this is what hornresp tells me, for a single horn. So I guess add 3dB to everything for the double horns in parallel. I'm fairly sure that that graph represents what would happen if the speaker was right in the corner of a room, so I'll probably end up taking in room measurements when they're built to position them well. As far as direct radiation from the drivers goes, the FE208EZ's are rated at 97dB each, so I'm aiming at an overall sensitivity of around 100dB. Hopefully any baffle step problems (if it is a problem with horns?) can be solved by careful room placement. As to outright max nice sounding SPL, enough I hope!
Thanks,
Steve
Old 3rd June 2004, 12:18 AM   #4
forgot the pic, that was pretty stupid of me...
Old 3rd June 2004, 01:02 AM   #5
dhenryp is offline dhenryp  United States
Beautiful!
The only concern I would have is lobing caused by having all three drivers running to very high frequencies (10k +) and with relatively large center to cnter spacing. The general rule of thumb is that MTMs should be crossed over at a frequency whose wavelength ~= the mid to tweeter spacing.
Old 3rd June 2004, 01:42 AM   #6
Cheers Henry, I did wonder about that, but I read some reviews on the Seventh Veils and they just said it lacked treble if you're stood up, but are fine when you're sat down with your head at the correct level. in my design the tweeter is bang on head height (1m) and the mids point inwards so they converge 2m away from the speaker, though im not sure if that helps. If it does turn out to be a big problem the top box is identical to the bottom one, so I could just take the tops off and use them for rears for SACD in the future...
I've attatched a response curve for all drivers with a 1uF cap on the tweeter and 2 fostex's run full range. (this doesn't include the horn response so ignore the low frequencies) though I don't know if this will help sort out the lobing issue. Tweeter to mid distance is 163mm btw, which would mean approximately 2000kHz? (344 divided by 0.163). But then if lobing isn't a problem if your heads on the 'centerline' im not too worried.
Thanks again,
Steve
Old 3rd June 2004, 01:46 AM   #7
Just remembered this too, on the T90A datasheet here fostex themselves seem to advocate the use of MTM with these identical drivers (This datasheet combined with Cain & Cains stuff was my inspiration for this, hehe) or at least using two fullrange drivers together anyway.
Old 3rd June 2004, 01:53 AM   #8
wigginjs is offline wigginjs  United States
wigginjs's Avatar
What did you use to do the 3D model?
Old 3rd June 2004, 03:08 AM   #9
Hesky is offline Hesky  United Kingdom
Hesky's Avatar
Awesome!! or should I say intimidating
I've been lookin into these full range drivers, there not exactly the last word in high frequency extension when compared to lowthers or the SV's little bandors. Somethin like 14K role off, so if thatís the case HF lobing may not be much of an issue if at all.
SolidWorks Student Edition? that blue background is such a give away
Hesky
Old 3rd June 2004, 05:56 AM   #10
DeonC is offline DeonC  South Africa
DeonC's Avatar
Default Re. mid to tweeter spacing
Hi Steve
How about solving two problems with one go. How about dipping the upper driver with 3dB - 6dB obove the baffle-step. That will solve any problems with lobing and such due to the large spacing relative to XO frequency. The overall efficiency will still be very high.
Enjoy,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Double Back Horn MTM projectHide this!Advertise here!
double horn, bib or angular spiral horn? testarossa2k Full Range 53 16th August 2017 08:19 PM
Double horn and electrostats. oublie Full Range 8 5th June 2009 02:07 PM
4 FR OMNI double horn hm Full Range 0 3rd August 2007 03:27 PM
FE126E back horn, 127E double BR : who really built it ? ow31 Full Range 29 14th June 2006 03:06 PM
double horn 108 ? brad212 Full Range 12 31st March 2005 09:07 PM
Copyright ©1999-2017 diyAudio
