Old 2nd June 2004, 06:44 PM   #1
Jhovis is offline Jhovis  United States
Default Buschhorn damping
There are two triangular chambers in the B'horn Mk2 design. I see mention of filling the bottom chamber with sand but nothing about the upper chanber. Should both be filled? I realize the sand in the bottom will also make it more stable. However, is it necessary for the upper and has anyone ever used an expandable foam like Good Stuff expanding spray foam?
Thanks,
jeff
jeff
Old 2nd June 2004, 06:52 PM   #2
Timn8ter's Avatar
The upper cabinet is usually stuffed with poly-fil or wool. It may not be wise to leave it empty as it would become a resonant chamber.
Old 3rd June 2004, 09:49 AM   #3
Colin is offline Colin  United Kingdom
Have a look at the zHorn site, where he recommends filling voids with some kind of architectural foam.
Colin
http://audio-resolution.com/zhorn/
Buschhorn MkII TB Mayday Full Range 0 31st March 2007 05:59 PM
Buschhorn Mk2 or 3? DaveCan Full Range 13 30th November 2005 09:39 PM
Buschhorn placement MichaelK Full Range 3 25th November 2005 05:34 PM
NSB in a buschhorn... nerd of nerds Full Range 0 25th September 2005 08:08 PM
Driver for Buschhorn Tuliman Full Range 8 14th July 2005 01:46 AM
Page generated in 0.08379 seconds (55.90% PHP - 44.10% MySQL) with 10 queries
