Spent a few minutes every day for a few months putting this together... it went through a lot of changes before I settled on this one.
And yes, I did do the math so that the each driver hit the minimum excursion needed to reach at least 109dB at 1m. |
#2 |
Crap! The section headings aren't bolded anymore!
#3 |
Slightly updated
#4 |
Nobody interested?
#5 |
Well, clicking on the attachment link fires up Acrobat which then procedes to dislike the attachment.
What's my problem? |
#6 |
I get text totally unformatted, run together in a stream-of-unconsciousness wad resembling a Dr. Bronner's soap label.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#7 |
have you listened to this set up?
...still looking for the holy grail. |
#8 | |
#9 | |
#10 | |
Precision-leveled poured Ceramicrete foundation Hy-Bor rebar-reinforced poured Ceramicrete rectangular room _Replaceable 30mm aluminum wall facing set into Ceramicrete (for wall fastenings) Cork flooring /w 8mm high-density chipfoam underpad Deep-pile Saxony treated wool carpeting 25mm wall paneling over fiberglass batt-insulated staggered stud double-framing _Wall paneling consists of gypsum facing, foamed aluminum structural member, rear bitumen coating _Bitumen-coated aluminum I-beam studs /w parabolic hollow Internal dimensions 3m x 4.8m x 7.2m or to scale HVAC system through aerogel-insulated tubing <+++Central Power Supply 1MWh vanadium redox power storage battery Carbon aerogel ultra-capacitor bank /w gold-plated 6N silver leads, oil-cooled aluminum housing _Capacity in megafarad range DC-DC power converters (to audio equipment power supplies) 120V/60Hz digital AC reconstruction (to standard power outlets) <+++Digital Equipment Basic Construction Point-to-point foamed Teflon PFA-jacketed UP-OCC 6N silver wiring when applicable Extruded copper enclosures Cast bismuth enclosure shielding /w ground hookup (outdoor pond) Pickup from power converters High-capacitance filtering/storing bank /w copper housing _Fast, low-impedance Teflon film capacitors /w rhodium-plated silver leads Teflon capacitors, metal film resistors /w rhodium-plated silver leads Avalanche photodiode inputs/sync from master clock Laser diode ST outputs <+++Master Clock Vacuum-insulated hermetically-sealed oven-controlled crystal oscillator _Synchronizes all devices through single-mode optical connections <+++Base Station IR receiver /w wired connection to electronic equipment, room lighting Programmable voice control Ergonomic handheld remote /w speaker/device selection, color LCD display Master remote controlling ‘tablet’ /w color touchscreen LCD display <+++Stereo Blu-Ray/DVD-A/SACD/CD transports Separate outboard power supplies for motor drives Kevlar-reinforced rubber belt-driven ultra-precise DC motors DLC-coated Ti Beta CEZ perforated disc platters /w vacuum disc clamping Vibration-isolated disc reading section Non-feedback current-conveyor current-voltage conversion Full 48-bit digital circuit resolution Built-in 0X/8X16X/32X/64X upsampling (all channels) /w voltage waveform shaping ECC DDR500 memory buffers Expandable DIMM slots <+++Digital Storage Bank Infinite-cycle flash memory-based fiber channel RAID storage MP3/WMA/AAC/WAV/FLAC/APE/copied DVD-A/copied SACD playback <+++Digital Crossovers/Equalizers – one per amplifier Butterworth/Linkwitz-Riley/FIR Hamming window filters Automatic full-range phase/delay/SPL/room gain/W-frame resonance corrector _Compensates for power compression over time _Manual control /w presets CF flash memory for response presets 64dB/octave band-pass filter at 15Hz and 32000Hz Digital volume control <+++Haven’t figured out how to power the infrawoofers so I’ll just say that each one should get a Pass Labs X1000 monoblock amplifier <+++Digital Amplifiers - 1 per woofer, midwoofer, or tweeter Adjustable “smoothing” filter – for poor recordings or harsher music PCM upsampler to DSD /w 7th-order noise-shaping feedback loop 1-bit pulse width modulation amplifying stage _128Fs switching frequency _+/- 32V power rails _Feedback loop to compensate for drop in voltage <+++Dipole Infrawoofers – reproduces 16Hz and above Bitumen-coated single-piece cast aluminum 2-driver W-frame Damped skeletal HIP SiC chassis // 4 arranged around listening position, 2 per W-frame // Suspension-limited excursion at about 40mm p-p, BL curve flat to maximum excursion // Diameter is about 45cm // Voice coil former diameter somewhere between 20cm and 25cm // Pole piece vent somewhere between 7.5cm and 10cm // Qts is about 0.5 // Fs below 16Hz, above 10Hz // Infrawoofer W-frame has at least 1000m effective path distance Diamond-coated Be I220H-IG diaphragm _Radially-ridged concave outer skin, triangulated inner structural support for greater stiffness, lower mass _Inner triangulations integrated with diamond-coated voice coil former _Accelerometer directs cone motion Multi-layer Kapton-coated UP-OCC high-gauge 7N edgewound beryllium voice coil Double progressive pleated fully-vented Nomex spiders _One raised spider forward of voice coil, other spider behind voice coil UP-OCC braided 7N silver tinsel leads (free-standing) Copper-plated Permendur quadruple-T-gap pole piece _Machined as mirrored DDD double-gap XBL2 (flux used twice) _Narrow coil gaps filled with ferrofluid Heavy copper rings above and below the T-shaped gaps 7N solid copper phase dome (oversized phase plug) Copper-plated Permendur gap plates _Rounded external edges _NdFeB axially-magnetized disc magnets between gap plates, Permendur “columns” __Stacked such that flux density between the two sets of gaps is equal Titanium fasteners <+++Hybrid dipole/monopole speakers HIP SiC baffle /w rounded edges _Extending-depth side panels for midwoofers, front baffle terminates over W-frame for woofers _Minimum distance between plasma tweeter and midwoofer _Midwoofer, tweeter horn not placed symmetrically on baffle to smooth out diffraction effects _Woofer/tweeter baffle has at least 400mm effective path distance _Woofer W-frame has at least 800mm effective path distance [Woofers] – 2 per W-frame firing in opposite directions, from 40Hz upwards // Suspension-limited excursion at about 15mm p-p, BL curve flat to maximum excursion // Diameter is about 35cm // Voice coil former diameter somewhere between 8cm and 10cm // Qts is about 0.5 // Fs under 30Hz, above 20Hz Damped skeletal HIP SiC chassis Woven carbon fiber/epoxy composite straight cone /w integrated voice coil former Multi-layer Kapton-coated UP-OCC 7N copper voice coil wire High-compliance half-roll foam minimum-width diaphragm surround Single pleated fully-vented raised Nomex spider /w butyl rubber edge termination _UP-OCC braided 7N silver tinsel leads (free-standing) Copper-plated Permendur double-T-gap pole piece _Machined according to Adire Audio’s XBL2 principle _Narrow coil gaps filled with ferrofluid Heavy copper rings above and below the T-shaped gaps 7N solid copper phase plug Copper-plated Permendur gap plates _Rounded external edges _N50-grade NdFeB axially-magnetized disc magnets between gap plates (saturates Permendur) __Stacked such that flux density between the two gaps is equal [Midwoofer] – from 100Hz upwards // Suspension-limited excursion at about 6mm p-p, BL curve flat to maximum excursion // Diameter is about 25cm // Voice coil former diameter somewhere between 4cm and 5cm // Qts is about 0.5 // Fs under 80Hz, above 50Hz Damped skeletal HIP SiC chassis Woven carbon fiber/epoxy composite curvilinear cone /w integrated voice coil former Single-layer Kapton-coated UP-OCC 7N SCCW underhung voice coil Flat foam ring diaphragm surround Single pleated fully-vented raised Nomex spider /w butyl rubber edge termination _UP-OCC braided 7N silver tinsel leads (free-standing) Copper-plated Permendur single-T-gap pole piece Heavy copper rings above and below the gap 7N solid copper phase plugs Copper-plated Permendur gap plates _Rounded external edges _N50-grade NdFeB axially-magnetized disc magnets between gap plates (saturates Permendur) [Plasma tweeters (1kHz – 32kHz)] – two per speaker for dipole operation _Rear tweeter rolls off at 6dB/octave after 1.5kHz, front tweeter compensating Kapton-coated UP-OCC 6N silver Tesla coil tuned to 1.5MHz 1.5% lanthanated spark electrodes Spark chamber heated to assist decomposition of ozone Constrained-layer steel constant-directivity horns /w copper mesh grilles (front/rear) _Somewhere between 60x40 to 90x60 dispersion <+++Cabling HIP Si3N4 electrical outlets _Self-cleaning rhodium-plated 6N solid silver contacts [Power] 6-gauge UP-OCC OFC 6N 20° twisted conductors _8-gauge UP-OCC OFC 6N ground _Extruded PVC jacketing _Stainless steel conduits for in-wall [Optical] Air-cooled high-powered laser diode transmitters _Wavelength of 1310nm _CNC-machined fused silica optics, sputtered silver reflective layer InGaAs/Si avalanche photodiode receiver _23.0um active area diameter, 1.0um absorptive layer thickness, 0.6um multiplication layer thickness Lapped/polished FC/PC connectors Single-mode glass fiber optic cable _Ultra-pure fused quartz core/doped cladding, 8/125 sizing _Extruded PVC jacketing _Braided Spectra strength member _Extruded PVC jacketing [Bass speaker cable] UP-OCC 6N solid silver conductors _Triple-layer OCC 6N foil/braid/foil OFC shield _Braided Spectra strength member _Extruded PVC insulation _5mm-thick bismuth nanoparticle-filled interference barrier _Braided Spectra jacket /w NBR lining [Treble speaker cable] UP-OCC thin-gauge 6N silver conductors twisted around core _Individual thin foamed Teflon PFA insulation _Teflon PFA foamed core _Triple-layer OCC 6N foil/braid/foil OFC shield _Braided Spectra strength member _Extruded PVC insulation _5mm-thick bismuth nanoparticle-filled interference barrier _Braided Spectra jacket /w NBR lining |
| How much less from the ideal??? | Leolabs | Solid State | 0 | 18th May 2007 02:54 AM |
| My ideal Sub plans | mashaffer | Subwoofers | 74 | 3rd June 2006 07:58 AM |
| What is the ideal sealed qtc? Anyone have luck with an aperiodic setup? | GuyPanico | Car Audio | 11 | 25th May 2005 08:14 AM |
| What is the ideal enclosure shape? | jmiyake | Multi-Way | 46 | 18th March 2005 09:00 AM |
| Listening room setup | Helix | Everything Else | 16 | 6th September 2001 12:49 AM |
| Page generated in 0.13871 seconds (85.09% PHP - 14.91% MySQL) with 11 queries |
