Old 1st June 2004, 07:58 PM   #1
Default 1& 1/2 way ?
Say I put a fe103 on a large ((30" by 60 ")) open baffel but wanted a little more bass. If I added another fe103 rolled
off with a inductor at say 150hz that would work sort of but
wouldn`t the bass from the first woffer be out of phase with
the second woffer?
Thanks,
Woody
Old 1st June 2004, 08:04 PM   #2
Phase will not get so far out of sync to actually cancel.
sreten.
Old 1st June 2004, 08:04 PM   #3
Timn8ter's Avatar
I think "little" is the operative word. I don't think an FE103 on an OB is going to give you anything at 150Hz regardless. How about putting a small woofer in a TL with the OB on top kinda like a mini Basszilla?
Old 1st June 2004, 08:04 PM   #4
I would say it depends on speaker location too, not only the cross-over.
Old 2nd June 2004, 10:22 AM   #5
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
i'd use the fw108 for bass. in any case teh 103 on OB wont give much below 200Hz.
...still looking for the holy grail.
Old 2nd June 2004, 12:27 PM   #6
Gregm is offline Gregm  Europe
If I added another fe103 roaled
Why not use a bog-standard, hi efficiency, medium/highish qts bass driver ?
Then you can try to equalise for BS. (easier said than done )
Page generated in 0.08517 seconds (76.74% PHP - 23.26% MySQL) with 9 queries
