Old 1st June 2004, 03:25 AM   #1
Default JBL 15" info?
Bought this JBL woofer recently. A 15", model number ME150H. Anyone have any information about it? Google search only turned up 2 hits. Was thinking of making a sub with it.
Old 1st June 2004, 10:50 AM   #2
Andreas is offline Andreas  Denmark
try the forum at www.lansingheritage.org, Giskard might have a clue.
Cheers
andreas
Old 1st June 2004, 12:15 PM   #3
mikee12345's Avatar
you could measure Fs Qes Qms and Vas
www.diysubwoofers.org
Old 1st June 2004, 12:47 PM   #4
Taken from some search on www.lansingheritage.org forums
Fs = 38 Hz
Qms = 6.4
Vas = 130.3 liters
Cms = 0.116 mm/N
Mms = 0.153 kg
Rms = 5.708 mohms
Xmax = ?
Xmech = ?
P-Dia = 337.5 mm
Sd = 0.089 sq.m
Vd = ?
Qes = 0.35
Re = 5.6 ohms
Le = 1.12 mH
Z = 6.72 ohms
BL = 24.2 N/A
Pe = ?
Qts = 0.33
no = 1.969 %
1-W SPL = 95.09 dB
2.83-V SPL = 96.64 dB
Old 1st June 2004, 02:18 PM   #5
Thanks for the help!
Old 1st June 2004, 06:32 PM   #6
Poke around www.partsexpress.com , I believe I saw it on there. You might be able to find more T/S parameters and whatnot.
Old 1st June 2004, 07:34 PM   #7
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
The Parts Express JBL was a subwoofer not this one.
The 150H was used in the S3100 speakers and 4344 Mk2
speakers. It was not sold separately
Quite expensive, and sold mostly in Asia.
The specs from Andreas are the same as I have found.
Apparently have overdamped bass, so not very strong but
lots of control. Not really a good sub driver. You could equalize
to bring up the lower frequencies, but there isn't really too much
excursion
I got mine cheap from American Science and Surplus.
What a deal!!! Sadly, they are out of these surplus beauties.
Do you have a supplier for these?
Mark
Old 2nd June 2004, 01:48 AM   #8
Sorry, but I have no supplier for these. I bought this from a surplus store and this was the only one they had.They were selling it for $19.99,and I thought it was too good to pass up.
Looking for Transistor based Gyrator info. Any "Wireless World" collectors out there? Hearinspace Everything Else 24 19th February 2011 07:58 PM
Info on "Jamo Dynamic d2e" speakers required John Biles Multi-Way 5 5th August 2005 07:02 AM
Need info about rare Siemens Cf "post tube" reaction Tubes / Valves 3 28th October 2004 02:37 PM
Page generated in 0.09372 seconds (74.48% PHP - 25.52% MySQL) with 11 queries
