Fresh off some sucesses with Lyra speakers and a third GainClone using BrianGT's boards, I'm looking for a new project and I think I want to build some quarter-wave pipes.
I'd like to build them around Fostex drivers (maybe the FE164 / 166E) since the general consensus seems to be that they offer the most favorable ratio in bang / buck computations. I've probably read all of the postings on this forum at least once and I've been to the quarter-wave and t-linespeakers sites, but I still have some questions. First, has anyone had any good FIRST experiences building these things with Fostex drivers (newbie, here)? Second, is the FE166E really a drop-in replacement for the FE164, or are there some design considerations. Third, I like the design of these, but I'd really like to use the drivers in this design and I want to use a single driver. Any ideas? Finally, I'll be using these with a non-inverted GainClone pushing about 40W per channel and since these drivers are more sensitive than my Lyras (the Fostex are 94dB, I think) I want to make sure the speakers don't wind up having the "Pete Townshend wuz here" look when I power up. Any recommendations would be greatly appreciated and as always, feel free to request any UN resolutions and I may be able to bring them up at the next UN open forum (wink, wink). Kofi |
#2 |
My first try with Fostexes (Fostices?) was a smashing success. See the recent threads about the FE107E. I'm thinking maybe next I'll try a project using the FE127E. The FX120 looks nice too, with its 2mm xmax - but pricey. I'm sold subwoofers, BTW.
Davy Jones |
#3 |
frugal-phile(tm)
I haven't met a Fostex i haven't liked yet... the FE167 in Bob Brine's ML-TL is very good. I expect the FE103s in Tim Forman's little ML-TQWT would also be good (they are very good with the RS40-1197s)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Cool! Thanks for the replies.
Do you think the GC will be too much for the sensitive Fostexessesses? Also, are you saying that I could use the FE167 in a quarter-wave tapered pipe and get away with it? Can I get the RS40-1197s over the web somewhere (it looks like RS only carries them in stores in Canada). Anyone got a favorite design? I like these for the aesthetics. I'd like to find a clone of the Abby if anyone knows of one. Sorry if these questions seem dim. The reason is that I'm dim. Kofi |
#5 |
OK-- more specific question here:
Will this design work with Fostex FE207Es? The designer (the speaker-picker, anyway), Dan Dicker, indicates that these may not perform as well as the 207s, but since I can't find any 207s, will the "E"s do? They seem to have a 50HZ response at just a little less than 85dB, but I'm thinking its got to be close enough here, right? Also, can I run these off a GainClone or will I be picking up pieces of an exploded driver while Mrs. Annan goes to stay at her sister's for a while until things cool down a bit? Kofi |
#6 | |||
frugal-phile(tm)
dave
#7 | |
Is the RS speaker that Bob uses in his straight pipe project (Model #40-1354a) the same as the RS40-1197? If so, I'd love to get my hands on some of those and I will be E-mailing you. It looks like this would be a great first pipe project. Thanks for all the information-- this is really a great forum. Kofi |
#8 | |
frugal-phile(tm)
Bob's 1354 project is an ML-TQWT so it gets larger towards the terminus. dave
#9 | ||
Man, that's just sad... I can't even successfully Google anymore. Kofi |
#10 | |
frugal-phile(tm)
http://alegriaaudio.com/bipole_voigt_pipe.htm picture back & front from this WEs mini-diyFest Having a few 1197s -- i'm going to build up a folded pair of these. dave
| Quarter Wave TL's and various Questions. | demon2091tb | Multi-Way | 4 | 22nd November 2006 06:19 PM |
| Help (very much) wanted for simple quarter-wave design for cheap drivers. | Spasticteapot | Full Range | 9 | 4th May 2006 09:14 PM |
| large quarter wave, HELP!! | psychosteve | Multi-Way | 5 | 8th October 2004 02:08 PM |
| Martin King: Is it just me or quarter-wave.com is down? Thanks | JC Fardo | Multi-Way | 7 | 12th September 2003 11:15 PM |
| Page generated in 0.13921 seconds (77.38% PHP - 22.62% MySQL) with 11 queries |
