Old 30th May 2004, 07:13 PM   #1
weidok is offline weidok  Netherlands
weidok's Avatar
Default TQWT Monacor Mindstorm
http://baseportal.de/cgi-bin/basepor...&cmd=all&Id=16
Anybody ever built this speaker??
There is NoBox like NoBox
Old 30th May 2004, 08:25 PM   #2
Tomac is offline Tomac  Croatia
Hi!
I haven't made this exact speaker ,but I've made TQWT with another Monacor driver - sph 60x.This seems as an interesting project.Both drivers seem to be good for the money.My previos experience with monacor drivers leads to a good opinon about this company. Whatever,I like the sound of my TQWT. Maybe this one could have a deeper bass if made longer,also the roll of at 500Hz could be a baffle step response problem.I think it is becuse I see no BSC circuit included.Make one,you'll have a deeper bass for sure if you add one. I heard that DT-107 is a good tweeter.I encourage you to make this speaker and to inform as on results
Cheers
tomac
Old 30th May 2004, 09:50 PM   #3
medum is offline medum  Denmark
medum's Avatar
Default speaking of Monacor speakers
Has anybody designed TL cabinets for Monacor SPH 135C?
Old 31st May 2004, 02:54 AM   #4
GM is offline GM  United States
GM's Avatar
No, but it's easy enough to do if I have specs.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 31st May 2004, 07:57 AM   #5
medum's Avatar
GM
http://www.monacor.com/en/produktsei...nummer=10.2310
Hi GM
I know it should be easy, but I do not have any experience at all about TL-cabinets so far, and I haven' yet found any software, that I could use for TL's. What kind of software do you use?
I believe the Monacor SPH 135 C is a fine little speaker for TL's but please correct me if I'm wrong.
I do not need a very high SPL, and I do have a good sub below 80 Hz.
Old 31st May 2004, 09:07 AM   #6
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Hi weidok,
the developer of the MINDSTORM is Theo Winterscheidt, the mastermind behind the german loudspeaker DIY forum "www.audiotreff.de". I couldn´t audition this loudspeaker yet, but AFAIK Theo puts his effort into getting max. results from affordable drivers. His TQWT definitely does NOT follows Martin Kings rules, but has been the result of some iterations in box construction. It took Theo 6 different enclosures before he was satisfied with the result. So you could do worse than follow his design.
Greets
Rudolf
www.dipolplus.de
Old 31st May 2004, 11:26 PM   #7
GM's Avatar
Greets!
>http://www.monacor.com/en/produktse...lnummer=10.2310
Interesting! I used the site's search function and got no info, so thought it was no longer listed or an incomplete model #.
What's been noted in many TL threads, MJK's: http://www.quarter-wave.com/
Don't have any experience with any Monacors, but it sims real nice.
Since this one is aneochoically flat to 40Hz, it should be an easy match up (assuming the published specs are ~accurate).
Max flat:
Vb = 0.6ft^3
Fb = 40Hz
L = 33"
S0/SL = 31.402"^2
Zdriver = 11.75"
Zport = 31"
density = 0.2lbs/ft^3
rp = 1"
Lp = 5.5"
All dims inside.
GM
Old 1st June 2004, 08:23 AM   #8
medum's Avatar
Thanks a lot GM
I've been studying Roger L. Sanders book on ESL-speakers, and a part of his book describes building TL-speakers for use with ESL-panels.
His guidelines are:
1 - Area of TL driver end min. 125% of speakerdiapraghm area
2 - Area of TL port end 100% of speakerdiapraghm
3 - Length min. 25% of the length of the fs wavelength
maybe this one works better
(at least it works fine from here)
Old 1st June 2004, 03:21 PM   #9
GM's Avatar
Well, with his design concept you have to use a high Vas, Q driver and heavily stuff it to get any LF, and then only a ~infinite baffle response.
Hmm, I see the attachment is corrupted for some reason. Looks fine at my end so let's try again:
GM
Old 1st June 2004, 04:40 PM   #10
medum's Avatar
I'm learning - Thanks again GM!
Monacor sph-135/AD Tomac Multi-Way 22 30th August 2006 04:30 PM
ML TQWT Monacor SP-200X weidok Full Range 6 10th April 2006 05:40 AM
Help me un-fold Mindstorm Tuliman Multi-Way 4 9th April 2006 04:43 PM
monacor goran14 Multi-Way 2 20th April 2005 02:12 PM
Monacor SPH 130 AL - anyone? andyjevans Multi-Way 10 8th December 2004 01:43 AM
Page generated in 0.11846 seconds (77.08% PHP - 22.92% MySQL) with 11 queries
