Old 30th May 2004, 08:00 AM   #1
Default Dayton Floorstanders
Well im looking to design a pair of floorstanding speakers to go with the sub a will be building but my question is can i model floorstandind speakers in WinISD the same way i did with the sub because i dont really see any posts telling you how to construct these sort of speakers?
Sory if i seem dumb
Greg
P.S The drivers i will be using in this design will be two dayton 8" woofers and a dayton silk dome tweeter.
Old 30th May 2004, 08:44 AM   #2
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
http://www.wadsnet.com/~dtenney/dayton_8MTM.htm
Deep down inside.
Old 30th May 2004, 11:07 AM   #3
Well I'll just throw in a twin 8" MTM is a bit much to partner a sub.
The D3 6.5" MTM may be a better idea.
And yes you can use WinISD for the bass alignment.
sreten.
Old 30th May 2004, 03:14 PM   #4
Banned
You should reconsider going with floorstanders with a sub. Floorstanders are generally full-range boxes; they stand on the floor as they need a lot of volume to support bass response and have to be tall enough for the tweeters to be at ear level. Since you're running a sub anyway you don't need the size of floorstanders for bass response; in fact, floorstanders will likely be too big to properly load the drivers. Then consider that with floorstanders you're consderably limited as to where you can put them.
Smaller MTMs that allow flexibility of placement would be more logical. As for drivers, again since you have a sub you don't need bass extension below 80 Hz at best, so go with 5 to 6-1/2" midbass drivers that will have far better response and dispersion characteristics than eights.
3 Way floorstanders jjbmon Multi-Way 3 26th January 2008 08:45 PM
FS AAD c800i Floorstanders Toast_Master Swap Meet 8 3rd October 2007 05:43 AM
My new floorstanders- nate Multi-Way 13 31st October 2006 02:27 AM
300 a pair floorstanders bjackson1 Multi-Way 0 19th June 2005 07:10 AM
JV80 floorstanders jose-emenace Multi-Way 2 14th June 2005 12:59 PM
Page generated in 0.08656 seconds (73.87% PHP - 26.13% MySQL) with 10 queries
