I'm looking for a "low q" 8 inch sub to be used in a very small passive radiator sub design. I want to try and keep the whole thing under 10" cubed using 3/4" mdf. It needs to handle at least 100 watts rms and have good excursion. Any and all suggestions (except any about using a different design) are greatly appreciated.
Thanks in advance, Sean |
#2 |
n/a
#3 |
10" cubed using 3/4 inch MDF ?
= 8.5" cubed internal = 0.35cuft = 10.1L. Nearly half of the external volume (0.58 cuft) is MDF. An 11" cube gives 0.5 cuft -14L , 12" 0.67 cuft - 19L. the 8" Tangband sub looks ideal : http://www.creativesound.ca/details.php?model=W8740C note : apparently Xmax is genuine, 24mm both way. |
#4 |
#5 |
That Tang Band driver looks like it will work great. Thanks alot sreten.
#6 |
Banned
A sub project using the TB 8 was in the last two issues of audioXpress magazine. Another contender at a very low price is the MCM 55-2421.
#7 |
I'm using winisd and get very long tubes for the 14 liter cube you sugest (11" cube), tuned to 28 Hz (Winisd sugests 92cm long port, with a diameter of 6.8 cm)
Am I making something wrong? How are you going to put a 92 cm long tube in a 28cm cube? You posted also winisd plots, so can you tell me what vent sizes have you obtained? Thanks Fernando |
#8 |
He's using a passive radiator, not a port.
#9 |
For a cube this size the tangband W8-740 is probably the best choice. There are other very nice 8" subs as well but most of them like bigger boxes. For a box that is a little bigger an Intertechnic MDS08 is a good contender too (nice kevlar membrane, casted chasis).
Fgomes: for BR in such little box, try calculating 3 br ports 20mm internal dia each( copper 22mm water tube?) Raise the Fb to 36Hz, tubes will be approx 130-140 mm long. Is that 14 L nett??
better be indoubt untill you're sure |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| In search of a 4" or 5" medium speaker | kepa1 | Multi-Way | 15 | 3rd January 2008 08:18 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.10650 seconds (72.18% PHP - 27.82% MySQL) with 11 queries |
