I have finished my first amplifier and now I need to put together some speakers.
I have the following: 2 x 10" 175Wnom 8-ohm disco subs. 2 x 2.5 inch 100W tweeters 2 x 4" dual cone car speakers (70-18,000Hz) (4-ohm impedance) (30W nom) 2 x 4" car speakers 10W nom I am thinking of building 2 3-way speakers consisting of a sub, midrange (car speaker) and the tweeter. I need to work out a passive crossover for these two speakers. What can I do with the 4-ohm car speakers? My amplifier can handle loads down to 4-ohm without any problems |
#2 |
Trying to throw together a bunch of disparate units can barely
be called loudspeaker "design", it may work, it may not. your 10" disco "bass" units will probably need to be reflexed and crossed over 1st order to the "mid" units at the baffle step frequency, this should give reasonable balance. The "mid" at a guess should be sealed off with ~ 3L volume. suggest 1st order series crossover at ~ 300Hz. The tweeter will need to be fitted with a ~ 20R "volume" potentiometer wired as an L-pad to balance its level with the mid unit. Without further info run the "mid" full range at the top end and blend in the tweeter with say ~ 2 uF cap and the L-pad. |
#3 |
so how do I wire the speakers?
I suppose I can wire the mid and tweeter in series and then wire them in parallel with the subwoofer? |
#4 |
"I suppose I can wire the mid and tweeter in series and then wire them in parallel with the subwoofer?"
Sure... if you want to blow the mids and tweeters. Please re-read (and then read it again) sreten's comments. DIY is all about learning from others.
Frank |
| designing a sub and fullrange box for several speakers... | mulletdude | Subwoofers | 116 | 17th July 2009 04:31 AM |
| Designing speakers for guitar modeling amp | JWK | Instruments and Amps | 8 | 3rd June 2008 03:58 PM |
| Help needed designing "Duntech-ish" speakers | boogs | Multi-Way | 16 | 17th August 2006 07:05 PM |
| Designing PA speakers | nicksmurf | Multi-Way | 34 | 15th August 2004 11:02 PM |
| Designing a Reference Speakers - 4 Way Active | HiFiNutNut | Multi-Way | 11 | 6th June 2004 05:01 AM |
| Page generated in 0.06963 seconds (74.43% PHP - 25.57% MySQL) with 10 queries |
