Old 27th May 2004, 08:31 PM   #1
Default First DIY Project
Hey guys,
As you can probably guess from my login name, this will be my first attempt at DIY Audio. I just bought a pair of Paradigm Reference Studio 100's and I was looking at subwoofers to go with them when the thought occured to me that I might be able to build one instead. Seems like an easy way to start, only one driver/type of driver so the cross over should be simple.. Then I started reading the boards and now I'm thinking its alot harder then I initially expected .. I was hoping some of you could lend me a hand. My main speakers are good to 44Hz, so I'm just looking to fill in the really subterranian bass with the sub. I want it to be musical, not the typicall HT type sub, but it will also be used for the LFE channel when I watch movies so I would like it to extend into the teens
Thanks in advance,
--Chris
Old 28th May 2004, 01:32 AM   #2
Hybrid fourdoor's Avatar
maybe one of the PartsExpress subwwofer kits might be your thing. You get really good product thats already been designed, but you get to put it together...so its till DIY
$350 you get everything you need, buy they have others as well
BTW: hi to fellow DFW'er
I enjoy my organic shapes.....
Old 28th May 2004, 01:40 AM   #3
Also if your more into not spending money
read my response in this thread....post # 10.
You can build the cabinet for less than $50. Then buy a 12" dayton regular sub and plate amp (all from PartsExpress) and it will probably run you $200 total.
Old 28th May 2004, 01:52 AM   #4
Thanks for the quick responses. I looked at the PEx subwoofer kits, but I think I want something that will extend lower. Since I started looking I have donw some modeling in WinIsd. How accurate are the results from WinIsd? It looks like i could design a sub with F3 around 16Hz with a Adire DLP12 and their 15" passive radiator. Is this too advanced as a starting point? Any other driver/box type recomendations? I did some reading on the forum about Linkwitz transforms and sealed boxes giving the flattest/most musical sound? Any comments/input would be greatly apreciated!
--Chris
Old 28th May 2004, 01:55 AM   #5
I recently built a sub. I've only had it a few days. So far, I'm very happy with it. I will definitely go down looooow. Check out the recent thread:
10" XLS semi-finished
Davy Jones
Old 28th May 2004, 02:28 AM   #6
Heres a plot and the PR setup of my theoretical box using the Adire DPL12 and PR15
I would like to know if this is a good design? WinIsd shows a completly flat response, is this realistic? Do I need any kind of equalization? Lowpass filter?
Box = 144L
--Chris
Old 28th May 2004, 03:27 AM   #7
No, you won't need any equalization. You've got pretty good response down past 20Hz, and room gain will push that up even more.
No, the flat response isn't realistic at all, you'll get nulls and peaks in the room. The flat line is just to show the rolloff of the driver in ideal conditions given the parameters you input.
Old 28th May 2004, 03:53 AM   #8
I noticed a couple of threads about building cylindrical Subs from Sonotubes. All the designs I saw had the drivers mounted on the bottom and the ports as well. If I want to do a passive radiator can I mount the driver on the bottom and the PR on top? or vice versa? Or do I need to do a cube in order to use a PR? Are there any advantages to doing an MDF cube instead of a sonotube? Do i need to add braces to my sub? What sort of bracing do I need?
Sorry for all the questions but I'm totally new to this!
--Chris
Old 28th May 2004, 12:49 PM   #9
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
Other than being a collecting point for dust and children's toys, having the passive radiator on the top shouldn't pose much of a problem as long as you don't have too much mass attached to the cone.
You could always save yourself some money and use a port instead of a passive radiator. With a sonotube style sub, I would think it would be more practical due to the upfacing PR that you just mentioned.
Old 28th May 2004, 01:11 PM   #10
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Passive Radiators should not be mounted horizontally. Gravity has too much of an impact with only the suspension to correct it.
Everyone has a photographic memory. It's just that most are out of film.
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
first project ceebmoj Full Range 5 23rd January 2008 07:51 AM
My first project, cool project. sorinsistem Solid State 3 19th January 2006 05:08 PM
Page generated in 0.10313 seconds (83.05% PHP - 16.95% MySQL) with 10 queries
