substitute for flush mounting
Old 7th May 2002, 07:30 PM   #1
Chris_W is offline Chris_W
Default substitute for flush mounting
Hi guys,
I'm planning to build myself a center channel this summer, and unfortunately a router is not in my budget (I'm a poor college student). I was wondering if its possible (and a good idea) to use a sort of faceplate with holes cut out for the drivers that would essentially make my speakers flush mounted. I've read something about doing this with wood, but what about some sort of foam, or maybe plastic? I'm looking for something that I could perhaps cut with a knife, or maybe even a dremmel tool.
Would this work well? and if so what would be a recommended material?
Old 7th May 2002, 08:23 PM   #2
psarin is offline psarin
i've used 1/8th inch masonite and 1/8th-1/4th inch felt with good results.
-p
Old 8th May 2002, 08:53 AM   #3
dinamic1 is offline dinamic1
If you make a sandwich whith the wood you are using and plywood ,youŽll never need a router.An image is better than one thousand words.Good luck.
Old 8th May 2002, 09:31 AM   #4
Thanks for both of your advice. It's good to know that I might be able to actually pull this off with somewhat of a minumum on tools.
To anyone whos tried any of the mentioned methods, what are the benefits of the different materials. ie. felt was mentioned and would probably damp any sound hitting the front of the enclosure, but wood was also mentioned which would be much more reflective. Anyway, just trying to learn, so if anyone has a link that they think might be useful that would be much appreciated as well.
Thanks,
Chris
PS. dinamic, you're right, a picture was definately worth more than words. Thanks
Old 8th May 2002, 05:38 PM   #5
cyclotronguy is offline cyclotronguy  United States
Default Poly-bendium
Westlake Audio, a very well respected pro-audio company uses closed cell foam as "wings" around some of their smaller studio monitors (emulating soffit mountings) to reduce diffraction effects. You should be able to use this detail to accomplish your goal with very little effort.
Cyclotronguy
Old 8th May 2002, 06:41 PM   #6
Digi is offline Digi
I have used felt, neoprene, laminated boards, and countersinking. My advice is to go with felt. It is easy to cut, gives you some room for error, and to boot it sounds great, especially with teeters and mids.
Sorry I don't have a link for you,
Digi
Old 8th May 2002, 09:34 PM   #7
tomcat is offline tomcat
Only use foam if you have already rebated the driver otherwise an uneven response will still result from the edge difraction off the driver flange, especially circular ones. With rectangular flanges it is less severe but there none the less. Felt as stated by others is very effective and easy to do otherwise use the methods suggested by others which has the added benefit of laminating the baffle and hence distributing and absorbing unwanted resonances especially if you use a lossy contact type adhesive.
tomcat
Old 9th May 2002, 12:59 AM   #8
Default my recent project with felt
you are welcome to have a look at a recent set of speakers i built (an implementation of the bipolar transmission line TL_B using RS 40-1354A) --see link below--.
in this construction, i started out meaning to use felt as a means of flush mounting, but ended up not using it that way - the RS 40-1354A already has enough of a weird cardboard rim around the mounting flange.
however, using felt all around did save me quite a bit of sanding/painting hassles! just sanded down all the MDF surfaces coarsely, sprayed with 3M Super 77 adhesive, and the felt went on like a charm. this adhesive is available at home depot etc, and is commonly used among DIY pool table makers to glue felt permanently to wood.
http://web.mit.edu/~sarin/www/tlb.html
Old 9th May 2002, 02:25 AM   #9
Thanks for the replies and letting me know that this will actually work. I really appreciate this since it seems many other forums don't want to reply to most posts that don't have to do with building subwoofers... Time to go study (damn).
substitute for flush mountingHide this!Advertise here!
Flush mounting speakers: the whole story loninappleton Everything Else 31 16th January 2013 03:06 AM
Tweet/mid flush mounting Puggie Multi-Way 3 17th January 2005 06:11 PM
Importance of flush mounting drivers RyanC Multi-Way 16 27th May 2004 09:10 PM
flush mounting subwoofers? Jhovis Subwoofers 1 30th December 2003 03:59 AM
Flush mounting anf cabinet geometry Dave Bullet Multi-Way 2 29th December 2002 06:46 AM
