Finally
OK Im finally going to build the speakers ive been dreaming of. Ive short listed the driver to the following
Either
1 Scan Speaker R2904 Ring Radiator 94.5 dB : 2 - 40 kHz fs : 520 Hz
2 ATC SB 75-150s – Midranges Radiator 94dB : 380hz – 5kHz fs : 320 Hz
1 Volt – Radial 3853 – 15” Woofer 93dB 30-500Hz fs 32hz
Or for the scaled down version which I may have to settle for
1 ATC SB 75-150s – Midranges Radiator 94dB : 380hz – 5kHz fs : 320 Hz
1 Volt – Radial RV3143 – 12” Woofer 91dB 39-700Hz fs 34hz
Looking to cross the woofer / midrange at about 400hz (15”) 600 (12”) and blend the mid/tweeter at about 2kHz
Any ideas, comments, criticisms, words of warning and words of advice welcomed
