Help i'm on a budget!!!!
Hi everyone. I am new to speakers and stuff and I am building my own sub. What i am having truoble with is finding the right sub speaker. Can you guys help? I want one under £40 , nice and loud, give a good vibration, good omff and be able to hear it from all round the niebourhood.
I have seen this one: http://www.maplin.co.uk/products/module.as...&moduleno=36764 is that any good?
This is what's going to be driving the sub: http://www.st-and.demon.co.uk/Audio/armstrong.html It is th 621 amp
I am using the amplifier to drive the sub and the input for the amp will come from my sourround sound. I know one of you said that 40w isn't going to give me much power but it is in the old scale and i am going to link up two of the outputs to make 80w (has anyone tried thiss before?)
By the sound of the replys i don't think the car sub is to hot. Do you guys have any other ideas or links to "better" speakers to use?
Thanks for the help so far:)
The simplest way of using both amplifier channels is using
two drivers, in parallel for high volume, or isobaric for a
small sub with more modest volume capability.
Though if you add say 0.33R series resistors to each channel
you could probably drive a 4 ohm subwoofer with the channels
in parallel. Do not connect the channels directly together.
Could use two of these isobaric (clamshell) ~ 60L tuned to ~ 28Hz :
http://www.bkelec.com/Diy/BSB12100.htm
:) sreten.
:) sreten.
That waterfall plot is hilarious.
Dannyball said:
So for each output have a seperate speaker??????????
Sorry for being a bit ignorant but i'm new to this.:rolleyes: :xeye:
Yup. Other options are a dual voice coil woofer, paralleling the
channels as detailed and theorectically bridging the channels
but I don't think the latter would work well.
Paralleling the channels (via 0.3 ohm resistors) and a 4 ohm
12" speaker reflexed in a say 2cuFt ( 55/60L) cabinet looks
about the easiest, but I don't know a source of good cheap
subwoofer drivers in the UK.
:) sreten.
Dannyball said:
Thanks for your help sp far now what should i go for?
2 of these together:
http://www.maplin.co.uk/products/module.asp?CartID=040524160456704&moduleno=24757&Products=1
Or one of the above
Or one of these:
Or one of these:
http://www.maplin.co.uk/products/module.asp?CartID=040525224658906&moduleno=36764
Remember i want some good omff, lots of vibration and be able to feel it!
:) sreten.
454Casull said:
40W won't give you much volume...
Bull crap.. it is never the amount of power for volume.. it is box and efficiency. i had a older pair of radio shack speakers that out performed a pair of verwin vegga's and the radio shack ones were 90x cheaper too..
never say power is the main reason.. it is all box and speaker efficiency
i was so impressed when planet10 showed me these little 4" speakers perform Man what a performance they did... i then realized that size and power means nothing...
of course you cant power a concert with 4" speaker's..
Tell me how you are going to make a subwoofer be heard from "all around the neighbourhood" with 40W with a budget of 50 pounds?
