Old 23rd May 2004, 01:14 PM   #1
Bernhard's Avatar
Default Horn formula ?
how are those horns called which are used in the big horn arrays from Avantgarde acoustic (?)
I think everybody knows which ones I mean, the round coloured ones, in three different sizes mounted together.
My question is - I believe all have the same shape, just different size - , what is the formula to calculate the curve ? are they simply hyperbolic ?
Bernhard
Old 23rd May 2004, 06:08 PM   #2
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
hornresp
Old 23rd May 2004, 07:47 PM   #3
GM is offline GM  United States
GM's Avatar
Looks like a Tractrix which are truncated hyperbolic horns, ergo don't load all the way to the mouth's Fc, though its technical Fc is per whatever its length + end correction dictates. In general, the horn loads down to ~1.414x the mouth area if long enough and with the right size throat.
Am = ~((13560/Fc/pi)^2*pi)/4
At = 2*pi*Fs*Qes*(Vas (ft^3)*1728)/13560
then:
x = a * ln((a + sqrt(a^2 - r^2)) / r) - sqrt(a^2 - r^2)
where:
x = distance from the mouth of the horn
a = radius at the mouth
r = radius at distance x from the mouth
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
box formula crs1 Multi-Way 29 23rd January 2008 09:53 AM
Q formula PeteMcK Multi-Way 10 17th January 2008 07:42 PM
gain formula xplod1236 Chip Amps 1 6th April 2004 04:47 PM
Need help on x-over formula Jay Multi-Way 3 12th August 2003 05:28 PM
Anyone have the formula for... Rino odorico Multi-Way 4 22nd January 2003 04:07 PM
Page generated in 0.07537 seconds (70.42% PHP - 29.58% MySQL) with 10 queries
