Old 23rd May 2004, 12:51 PM   #1
teodorom's Avatar
Default Bass Reflex design using MJK software
Hi all,
when in a Bass Relex the vent is on the opposite side of the driver (so zdriver~zport), what are the correct settings for the appropriate MJK worksheet ?
The answer is the simplex one, or there are some complexities ?
Teodoro
Old 23rd May 2004, 01:31 PM   #2
Timn8ter's Avatar
It's the simple answer, distance from the top. I've always wondered why someone would want to do that. AFAIK, the highest compression for loading the vent occurs near where two or three panels meet. It also seems the most likely occurance of upper frequencies exiting the vent would exist with the port directly behind the driver.
Old 23rd May 2004, 05:16 PM   #3
teodorom's Avatar
Default I'm trying to understand, but not only that ...
I'm tring to understand if I can do similar to the Coral RS3000 project.
That is a camber with the mids driver (Peerless HDS 134) on top, and a TL (Peerless HDS 182) on the base.
So I need some S0 for the TL (440 cm2 would be better, 405 cm2 -and a 152 cm line- still gives -with a 0.6 filling- acceptable results).
I would like to use the TL to get 20 more Hz and some sort of "baffle step compensation" (so the HDS 182 will go backward and will have an appropriate impendance in series).
I'm still simulating ...
Teodoro
tiny bass reflex design? xdissent Full Range 7 13th May 2008 09:57 PM
HELP! Bass-reflex design for vintage University woofer C-15HC davidbosch Subwoofers 9 12th December 2007 02:26 PM
whats to be gained from an elaborate box design over a std. bass reflex? demogorgon Multi-Way 11 8th March 2007 05:30 PM
how to design a series tuned double bass reflex/ABC enclosure Puggie Subwoofers 0 1st May 2006 01:47 PM
Lambda TD12s Closed Box / Bass Reflex Design akunec Multi-Way 7 13th September 2005 02:44 AM
Page generated in 0.07528 seconds (71.12% PHP - 28.88% MySQL) with 10 queries
