Passive EQ to active EQ - Page 2 - diyAudio
Old 23rd May 2004, 04:25 PM   #11
Svante is offline Svante  Sweden
Svante's Avatar
Originally posted by Nuuk
I had another think about this and wondered about including the EQ, or at least the bass 'lift' in the feedback loop of the inverted Gainclone circuit.
This would save including more opamps in the signal path. Any ideas or comments on this?
Given that you find the right circuit, it would be cheaper, better, simpler. Actually I cannot see any reason not to do it, if you are building the power amp anyway.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 23rd May 2004, 09:52 PM   #12
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
What exactly does your current PLLXO do, (asking is easier than getting my brain in gear to calculate frequencies)
I know that feeling well Al! I provides a bit of lift at the low end (60 Hz up) to counteract a slightly rising response) and a bit of lift at the top end.
BTW -what is PLLXO?
I hope you realise that there should be a resistor to gnd on the first opamp, and decoupling capacitors for the power etc. You probaly knew this, but just in case...
Yes thanks, I did but it never hurts to make sure.
Thanks again. It always helps to know what the the correct question should be in order to get the correct answer!
I don't know exactly how to do this but I think that I know a man who can
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 23rd May 2004, 10:29 PM   #13
Matttcattt's Avatar
BTW -what is PLLXO?
Passive Line Level Cross Over (I think :P )
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 24th May 2004, 07:59 AM   #14
Nuuk's Avatar
Thanks Matt, that sounds about right to me.
active vs passive xo howard99 Multi-Way 4 25th July 2007 12:55 PM
Active or Passive bjackson Multi-Way 30 4th April 2005 10:49 PM
Active of passive audiobomber Multi-Way 9 31st July 2004 02:31 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Passive vs Active I/V HeadSh0T Digital Source 1 7th May 2003 10:12 PM
Copyright 1999-2017 diyAudio
