Old 22nd May 2004, 05:28 AM   #1
stool is offline stool  United States
Default design help
I am wanting to build a bass reflex cabinet. I am using and trying to understand Speaker box lite. The driver specs are: Fs=41, Re=5.1, Sd=880 sqcm, Qms=5.9, Qes=.39, Qts=.36, Vas=154.82, Mms=106.73, Bl=19.09, Xmax=5.5, Le=1.46, Hvc19, Hag=8, Cms=178.56. What I came up with is a 81 liter box, which is about what I was looking for. A box Q-value of 7.9, not certain about this, can someone explain. Four ports with 3.8cm diameter and lengt of 1.9cm which would be the thickness of the baffle board. The resonant frequency is 40.5Hz with a -3db at 52.05Hz. The free airspace SPL at 1m rolls up and then flattens out a little above 100Hz. Would it be better if it started flat, then rolled up and then flatten out again? Any and all info will be greatly appreciated.
Old 22nd May 2004, 09:12 AM   #2
Looks about right, though I like the look of 120L tuned to 34Hz.
For your 80L/40Hz box you need an ~ 100mm diameter x 110mm length port.
Trying to use the baffle width as a port length won't work well.
sreten.
Old 22nd May 2004, 06:46 PM   #3
Thank you for the port/baffle comment and the other as well. As far as box Q-level, any particular range best. The speaker mentioned is the P.Audio P150/2226, I was trying to decide upon that or the B&C 15 PS40. Anybody familiar with these or the 12" equivalent P.Audio P120/130LF or the B&C 12 PS32 or PZ32 willing to comment. I was not wanting to get into brands, but this is something that probably should be asked. I would like to keep this at 100 liters max, but not mandatory. Thank you.
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Page generated in 0.07026 seconds (66.37% PHP - 33.63% MySQL) with 10 queries
