Old 22nd May 2004, 03:59 AM   #1
rnoble is offline rnoble  Australia
Question Sonotube considerations
I have been browsing here as a guest for a while but this is my first post officially.
I am planning my first DIY project - a sealed sonotube design and I was wondering if I could ask for some good advice in regards to the plate amp placement.
The diagram below shows the proposed design in rough form (If you could please excuse my drawing skills, the bottom grey box is the plate amp. ):
The gap between the driver and plate amp is a healthy 150mm (6").
The Questions are:
1. Does anyone forsee any heat related problems with heat 'rising' from the plate amp to the driver?
2. Does anyone forsee any problems mounting a plate amp horizontally like this instead of the traditional vertical mount?
Any other suggestions are also very welcome. I will post pics as they come to be taken during the build process.
Kind regards
Rod
Old 23rd May 2004, 02:14 AM   #2
1. No.
2. I think the fins work better in a vertical position, but the moving air will probably make up for that.
Old 23rd May 2004, 07:07 AM   #3
Thanks for that, I have decided to go with the KISS principle on my first DIY so I am not including the amp with the sub, I'm making a separate box for it. This way less to go wrong.
Old 23rd May 2004, 07:11 AM   #4
Hybrid fourdoor's Avatar
Well you've hit the unspoken pain thats associated with Sonotubes....putting a plate amp somewhere.
Its true what they say...there are always compromises. You can build a Sonotube for like $30 and one trip to Home Depot (actually I like Loewe's Sono's better), but then you can't stick a <normal> plate amp on it like you can those big expensive square monsters.
I think most poeple just remote mount the amps. You could mount the plate inside and just move the knobs/connectors to the cylinder.
I enjoy my organic shapes.....
Old 23rd May 2004, 11:58 AM   #5
They're not that cheap here either, sonotube is around $50 a meter if you want short lengths.
Old 23rd May 2004, 01:55 PM   #6
Timn8ter's Avatar
I think putting the amp in a separate box is a fine idea.
Placing the box under the amp will make it difficult to reach the controls.
Old 23rd May 2004, 03:36 PM   #7
Jhovis is offline Jhovis  United States
I built a HT sonotube in 2002. I used an 18" (45.72cm) sonotube with a 15" (38.1cm) subwoofer. Mine is ported and stands approx 72" (189cm) tall. I have a component rack built into a wall and the sub amp is mounted in that rack. The sonotube here is sold in 12' (3.7m) lengths. I bought mine at a commercial concrete supply company for a relatively cheap $65US.
Here is what I built: http://europa70.tripod.com/diy_sonosub001.htm
jeff
Old 23rd May 2004, 03:50 PM   #8
Is your plateamp mount fiberglassed? Or is that wood? Nice either way.
Pre-amp considerations. jerryo Solid State 41 29th May 2008 05:03 PM
More MTM Considerations DonoMan Multi-Way 5 3rd March 2005 06:29 PM
Page generated in 0.10555 seconds (73.77% PHP - 26.23% MySQL) with 11 queries
