Old 21st May 2004, 09:20 PM   #1
Default Help with edge.exe
I've got a problem with edge.exe. I decided to find out what would happen if I put big numbers into the fields "edge sources" and "speaker source density." Well now I know. :-) It takes several minutes to make a plot, and I can't change the numbers back to small ones. When I try to use the spinner button to change the number, it instantly starts doing a plot with the number reduced only by one. Two or three minutes later I can reduce it by one more. At this rate I figure it will take me about 36 hours to make the program usable again. I've looked for a data file to edit "by hand," but I didn't find it.
Pleads hep me!
Davy Jones
Old 21st May 2004, 09:57 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Command line option
Start the edge from start|run with the command line switch "/n" (without quotes) to start with a fresh baffle design. This might be useful if the present design has become irreparably complex J, or if any of the windows have ended up outside the screen etc.
Sorry about this...
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 21st May 2004, 11:38 PM   #3
Originally posted by Svante
Command line option
Sorry about this...
Thanky!!
Davy Jones
edge question pforeman Full Range 3 10th July 2010 02:02 PM
Svante's the EDGE Pano Multi-Way 11 20th January 2007 09:57 AM
Close to the Edge PeteMcK Multi-Way 15 13th July 2005 10:54 PM
Diffract.exe is no more, try the edge! Svante Multi-Way 69 11th May 2005 05:04 AM
Edge connectors - which to use? andyjevans Tubes / Valves 4 8th January 2004 09:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
