Old 21st May 2004, 04:21 AM   #1
Default paint suggestion?
I searched, but suprisingly came up empty.
Can someone recommend some kind of crinkle paint or something that will put a respectable finish on MDF with a minimum of work and skill?
... and I thin que very much.
Davy Jones
Old 21st May 2004, 05:13 AM   #2
Jye is offline Jye  Australia
Jye's Avatar
Hi Dave,
This stuff is great and really easy to use.
Truck bed liner
Enjoy
Old 21st May 2004, 07:16 AM   #3
GM is offline GM  United States
GM's Avatar
Scroll down:
http://www.hometheaterforum.com/htfo...hreadid=174318
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st May 2004, 04:08 PM   #4
herm is offline herm  United States
Dave,
I used Stone Creations that you can buy at Home Depot
or Lowes. See my speakers here:
My speakers
It takes a little preparation, but it really looks good.
E-mail me with questions...
-herm
Old 21st May 2004, 05:34 PM   #5
I like hammer finish spray paint. Available at Home Depot. Hides minor blemishes. Fairly glossy. Limited color selection, though.
Old 21st May 2004, 08:36 PM   #6
I have an old recipe for painting speaker boxes using
that stone paint mentioned previously.
1-2 coats white primer
1 or 2 coats of desired colored house paint, perhaps gloss
would look nice. (oil or latex you choose).
1 'sprinke coat' of stone paint.
Stone paint: The trick is to do only partial coverage, not
100% coverage as it will 'paint over' your finished paint.
You stand back far away when straying the stone paint
using quick 'blasts' so you get 'sprinkles' on top of your
painted finish. Not too little, not too much. Uniform application.
This gives you an interesting look.
Ideally, if your base color is dark, you use light colored stone
paint. If the base color is light, you use dark color stone
paint for good contrast.
Wild card idea;
You use fluorescent spray paint as your base color instead of
using the colored house paint. Probably 2 coats of primer
in this situation.
What's the worst paint job you ever did Iain McNeill Construction Tips 17 Yesterday 03:08 PM
mdf paint joshuajoshua Multi-Way 16 8th September 2008 02:36 AM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
Page generated in 0.08291 seconds (74.95% PHP - 25.05% MySQL) with 10 queries
