Old 21st May 2004, 12:27 AM   #1
jonz is offline jonz  Canada
Default How to hook up Speakons?
I bought an amp that has speakon connectors and I would like to use them ...I am confused about the connections on them...they have 4 setscrews 2 in 2 out..how do I connect a regular two conductor pos+neg speaker wire?
Old 21st May 2004, 12:29 AM   #2
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
if im not mistaken, its setup for accepting a stereo pair of speakers... so, 2 wires, 2 speakers, 4 connections. you can either use them for a single speaker each (either just use 2 wires, or double-up on them), or use a single jack for a pair of speakers.
Old 21st May 2004, 12:30 AM   #3
Warp Engineer
On Holiday
AudioFreak's Avatar
Check the amp manual but you can usually just use 1+ / 1-
- Dan
Old 21st May 2004, 01:05 AM   #4
Which connection on speakon is positive and which is neg,since there is 4 of them two in center and 2 on the outer shell?
Old 21st May 2004, 01:55 AM   #5
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
If you look carefully at the base of each screw, you'll see 1+/1-/2+/2-...
They're not easy to see at first sight !
Old 21st May 2004, 02:25 AM   #6
thanks Elkaid...thats what happens when you hit 45...
FS: Half Complete DIY Project (SEAS Drivers, Speakons, Biamped)--Very Detailed gtphill Swap Meet 0 13th June 2008 07:13 PM
speakons in canada. neutron7 Parts 2 23rd February 2007 03:48 AM
Did I hook this up right? HolyGhostFire20 Parts 7 6th August 2005 09:15 PM
Hook-up Wire? mwh-eng Tubes / Valves 6 4th March 2004 07:30 AM
CD Recorder Hook-up jschiltz Digital Source 1 16th February 2004 09:48 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
