Old 20th May 2004, 10:38 PM   #1
ShinOBIWAN's Avatar
Default Crossover experts, help me please.
Although I'm not new to building boxes, I am a total new comer to the world of hifi crossovers.
Here's the troublesome crossover schematic:
Which is basically for this
What I really need your help with is identifying the components from the schematic. None are labelled as to what they are for somebody with no experience with this before.
Many thanks to anyone who replies with answers.
Old 20th May 2004, 11:18 PM   #2
Timn8ter's Avatar
Inductor = solid black rectangle
Resistor = white rectangle
Capacitor = two parallel lines
Connection points = solid black circles
Old 20th May 2004, 11:36 PM   #3
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Interesting, two tweeters wired out of polarity to each other
left lane is for passing, slower traffic keep right please.
Old 20th May 2004, 11:40 PM   #4
leadbelly's Avatar
One is labelled front and one is labelled rear. It is a dipole.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 20th May 2004, 11:47 PM   #5
Timn8ter's Avatar
Dipole for surround speakers. Looks nice!
Old 20th May 2004, 11:48 PM   #6
ShinOBIWAN's Avatar
Many thanks Tim!
Just one more question, do I need to be concerned about the denotations on some of the components? ie. Some of the Inductors have 'SP' or 'FC' and likewise for the capacitors with 'ELKO spez' and 'ELKO rauh'. The last two are German but of course I don't know a word of it, so any Germanics care to shed some light on this please?
Old 20th May 2004, 11:50 PM   #7
ShinOBIWAN's Avatar
It is indeed.
The link above doesn't work thank to my less than adequate paste job.
This should be the right place this time.
Old 20th May 2004, 11:52 PM   #8
SinOBIWAN I think the components as these. (i) the solid black rectangles are inductors. The values are in millihenries and the larger ones (3.9 and 6.8) are iron/metal cored. I guess the "F" in the FC stands for ferrite/ferro. The smaller values (1.5mH or 0.22mH) are air cored and they have given you the diameter of the wire in millimeters (1.0mm and 0.6 mm). I know a bit of Biblical Greek and the "P" may stand for the Greek word for "wind/breath" which is "pneuma" as air powered tools in English are "pneumatic". (ii) The open rectangles are resistors with values in "ohms" and the "watts" give the power rating. You can use larger power rating but best to avoid smaller ones. (iii) the components with parallel lines are non-polarised capacitors and the values are given in micro-farads. I'm not sure what "rauh" and "spez" are but they could mean "electrolytic" and "plastic film". The components on the right hand side of the diagram are the drivers/speakers and the numbers will be part numbers from the manufacturer.
European readers who know the language may able to be more helpful. Jonathan Bright.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 20th May 2004, 11:57 PM   #9
Jean's Avatar
Somehow I missed that !
Old 21st May 2004, 12:02 AM   #10
ShinOBIWAN's Avatar
Wow you know your stuff.
Top man and give yourself a pat on the back.
I pretty much know what I need to be ordering now, I already have the drive units on order but need to build the crossovers myself. Should be a good first experience for me, because as I understand, its a rather complicated arrangement. So next time I'll be a dab hand at this
I'd be grateful if anyone can just clear the 'rauh' and 'spez' issue on the caps-see I almost sound as if I know what I'm talking about now
4th BP experts? danielm Subwoofers 4 20th July 2009 04:47 PM
DHT experts, i need your help Cassiel Tubes / Valves 10 25th February 2009 01:42 PM
Crossover Experts Help Please Bigred Multi-Way 6 5th November 2007 06:22 PM
passive crossover related questions- calling all experts! nobody special Multi-Way 2 7th November 2003 08:04 PM
Crossover Experts! Hole in 12dB/octave, (both sides), response? Help!! kelticwizard Multi-Way 14 17th July 2002 08:45 AM
Page generated in 0.11717 seconds (79.76% PHP - 20.24% MySQL) with 10 queries
