Old 20th May 2004, 08:55 PM   #1
jjdche is offline jjdche  United States
Default W3-871s, Does doubling the drivers affect the notch?
I'm considering doing John's notch filter for the Tang Band W3-871s but I wanted to double the drivers to get some more SPL. Would doing this affect the function of the notch filter as published? Obviously, the impedance would be different, but I don't know if that effects anything else.
Old 20th May 2004, 09:17 PM   #2
5th element's Avatar
Yes it does, because the notch filter works on the impedance of the drivers if you change the drivers impedance you need to change the notch filter.
Double cap values and half inductor & resistor values if you are connecting two in parallel.
Matt
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 20th May 2004, 09:33 PM   #3
Thanks.
This forum is great, so much knowledge right at your fingertips!
Old 20th May 2004, 10:06 PM   #4
Timn8ter's Avatar
Are you going to tell us what you're building?
Old 20th May 2004, 10:35 PM   #5
I'm going to be building this thing that I posted about a few days ago. I've re-thought the design a bit and been looking into some different options that people mentioned, particularly the W3-871s. Not fiberglass though, I don't think I'm up for that.
I want to use it as a PC speaker system as well as a portable system. I don't know if a single W3-871 per side will be enough volume so I might go with two. I'll probably try both configurations and see how they compare.
Old 20th May 2004, 11:20 PM   #6
Timn8ter's Avatar
Right on! Something different!
Old 21st May 2004, 12:05 AM   #7
Hey, thanks for the support. I'll keep everyone updated on the progress (assuming I actually make some progress ).
Old 21st May 2004, 01:50 AM   #8
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
so you went with my suggestion on the W3-871s's and a dayton 8?
Old 21st May 2004, 02:33 AM   #9
yup, thanks for the suggestion. The savings in weight and $$$ were too much to ignore and with all the buzz around here about those little drivers I wanted to say that I at least gave them a shot!
Old 21st May 2004, 12:02 PM   #10
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
Good speaker combo. I just listened to my w3-871s & Dayton 8" DVC combo together for the first time last night.
I was impressed.
Fs: Tang Band W3-871s drivers norman bates Swap Meet 17 13th November 2008 09:44 AM
wtb: tang band w3-871s drivers norman bates Swap Meet 0 15th September 2008 06:19 AM
FS: external notch filters for Tangband WS-871s speakers jives11 Swap Meet 5 31st October 2006 10:44 AM
Doubling carlmart Solid State 19 14th July 2004 07:48 AM
Measuring Drivers TB-871S - Help! gregorx Multi-Way 24 3rd August 2003 06:02 AM
Page generated in 0.11323 seconds (67.45% PHP - 32.55% MySQL) with 10 queries
