Hey, Hows it going.
I recently purchase a 12" Pioneer TS-W304F Sub and I'm still undecided on wether or not to put it in a sealed or ported enclosure. I'm going to be putting it in the boot (trunk) of my E36 BWM, so size may be a constraint. These are the specs if they are at all helpful. Revc: 3 ohms Levc (mH): 0.927 FS: 32.3Hz Qms: 7.903 Qes: 0.581 Qts: 0.541 Vas: 3.062 cu. ft. / 86.7 litres Rms (N.S/m): 2.519 Mms (g): 97.95 Cms (m/N): 2.484 * 10 -4 (Scientific notation) Diam: 9.9" / 251mm BL (T.m): 10.222 Xmax 0.44" / 11.2mm I'd appreciate any help you guys could give. I tend to be heading towards a sealed enclose due to it's smaller space requirements but I'm willing to put my proverbial on a chopping block that you guys know more. Thanks Alot Thomas Fowler South Africa tgfowler@icon.co.za |
#2 |
I wrote your numbers for the Pioneer into WinISD, which did not have them on the database.
Arbitrarily, I decided to give all boxes a volume of 2 cubic feet, for equal comparison puroses. Red: Vented, tuned to 28 Hz. A lttle hump, but still a good response. Improvement over sealed. Blue: Sealed, with a volume of 2 cubic feet. Brown. Bandpass with the following parameters. Front chamber, (in front of woofer): .9 cu ft. Rear chamber: 1.1 cu ft-no vent in rear chamber Tuning: 52 Hz. A 3" diameter port, 8.5" long. The bandpass is a little less output over 45 Hz, but some people just have to have substantial output down to 30 Hz. Anyway, the choice is yours. Of course, the box does not have to be 2 cu ft. Let me know what you are thinking size-wise. I just wanted to illustrate that a 2 cu ft box has 3 usable possibilites. |
#3 |
Oops.
My quote, above, for bandpass box: "Tuning: 52 Hz. A 3" diameter port, 8.5" long." Make that 6.5" long. |
| A Pioneer B20 Enclosure... | shloky | Full Range | 6 | 13th September 2007 12:06 PM |
| pioneer subwoofer enclosure | grujo | Subwoofers | 1 | 5th July 2005 11:40 AM |
| pioneer sub 4 home use. what enclosure?? | felzi | Subwoofers | 18 | 13th June 2005 06:08 PM |
| Page generated in 0.09820 seconds (63.56% PHP - 36.44% MySQL) with 11 queries |
