JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakers
Old 18th May 2004, 08:55 AM   #1
mark.carline is offline mark.carline  United Kingdom
Default JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakers
I am now thinking about making a centre channel speaker to match my Focal Triga (see my other thred) and I am wanting to use either the same or similar tweeter / midrange drivers as my main speakers:
TC 120 TD5
http://www.focal.tm.fr/gb/compo/tweeter/tc120td5.htm
and:
Audiom 6 WM
http://www.focal.tm.fr/gb/compo/midrange/a_6wm.htm
The problem is that the "Audiom 6 WM" is a midrange driver and not a midbass driver.
I am therefor considering using the following driver as its a midbass driver:
6 W 4311
http://www.focal.tm.fr/gb/compo/midbass/6w4311.htm
But the question I have is that is there *REALLY* much difference between these two drivers. When you compare the frequency frespence theres not that much difference, see:
Audiom 6 WM - FS:
Old 18th May 2004, 08:57 AM   #2
Default 6 W 4311
6 W 4311 FS:
Old 18th May 2004, 09:45 AM   #3
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
i dont know but i see significant differences in the 2 freq. rsponses.
...still looking for the holy grail.
Old 18th May 2004, 01:04 PM   #4
Seth Smith is offline Seth Smith  United States
ditto
Cynics regard everybody as equally corrupt...Idealists regard everybody as equally corrupt, except themselves.
Old 18th May 2004, 01:30 PM   #5
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Looks like significant response to me. You might also want to look at the 7W4411, as it goes a bit lower.
Brian
Old 18th May 2004, 06:03 PM   #6
sma is offline sma  Indonesia
i meet focal engineer several month ago,and my question is same with you.are you plan building 2 or 3 way system?if 2 way you can use 6W4311 and TC120TD5 because audiom 6W is very high efficiency driver,and you must use same audiom TLR tweeter for meet same speed,same coherent sound.
I found same condition in my experiment.if you plan use audiom,u must use same audiom tweeter and additional focal woofer or subwoofer for add the low bass frequency...and as i know focal crossover need very complicated crossover design..i already try make DIY speaker use focal driver and i am still can't found sound better than my JM Lab electra906.
JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakersHide this!Advertise here!
O/B Centre Channel Cloth Ears Full Range 7 15th January 2009 03:25 PM
Pass Labs X5 for a multi-channel Thiel speakers setting? JulienG Pass Labs 5 21st August 2007 03:44 AM
Phantom centre channel with centre channel lol Toast_Master Multi-Way 5 5th December 2006 03:54 AM
Audax Centre channel crossover for midrange jtfoo Multi-Way 6 30th March 2005 12:21 PM
Centre channel for my Focal Triga mark.carline Multi-Way 0 28th May 2004 03:58 PM
Copyright ©1999-2017 diyAudio
