Speaker impedance too low for amps!
Old 18th May 2004, 08:40 AM   #1
paulj is offline paulj  Australia
Location: Warrandyte - outer "bush" suburb on the Yarra River, outside Melbourne Australia
Default Speaker impedance too low for amps!
I was about to buy some particular speakers until I was advised they had a nominal impedance of 4 ohms: my amplifier set-up (2 x Cambridge Audio) can only handle 6 - 16 ohms, according to the instruction book. I am scared of damaging the amps. Is there any simple way of safely fixing this problem without degrading the sound or endangering the amps (or the 4 ohm Klipsch KG4 speakers, circa 1984, that I wanted to buy)?
Old 18th May 2004, 11:24 AM   #2
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
The KG4s are rated at 100 watts RMS power capacity and they are also high sensitivity (94dB) so you don't need a lot of power to get a lot of sound out of them. Your amps should be confy with those, as long as you don't try to rock the whole house.
Old 18th May 2004, 12:32 PM   #3
Yes, but isn't the 4 ohm impedance of the speakers i8n danger of damaging the amps, which can only handle 6 - 16 ohms?
Old 18th May 2004, 12:41 PM   #4
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Why not contact Cambridge Audio and ask them?
Frank
Old 18th May 2004, 01:23 PM   #5
boholm is offline boholm  Denmark
boholm's Avatar
No. It is not a question of matching 8 ohms to 8 ohms, 4 ohms to 4 ohms . . . .
It's more like having a big truck with a small engine. As long as you drive safe and carefully you will not notice the small engine. But if you want to go very fast or accelerate very quickly, you may destroy the engine.
If the amplifier has built-in protection you can go ahead and test the speakers on your amplifier. If not, then you can still test but you must turn up the volume nice, easy and slowly. If it is loud enough for you in mid position, then you are safe IMHO. Higher than that, then I would start to have second thoughts about the speakers.
Best regards
Bo
Old 18th May 2004, 01:39 PM   #6
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
It's hard to say. Back in the seventies, they had amp circuits that simply were not comfortable with 4 ohm loads, regardless.
Assuming that Cambridge does not have a similar problem, (the seventies were a long time ago), then your maximum output into 4 ohms will be slightly reduced.
If your Cambridge setup gives 100 watts into 6 ohms, then when working at it's maximum, it is giving 24 Volts into 4 Amps, for a total power output of 96 Watts.
Since 4 Amps is as high as it goes, into a 4 ohm load it can only give 16 Volts into 4 amps, for a total power output of 64 Watts.
Working it out, that means the Cambridge can give 1.7 dB more maximum power into a 6 ohm speaker than into a 4 ohm speaker.
However, if these speakers are actually 94 dB @ 1M/1W, then they are far more efficient than normal speakers, and you won't need that extra 1.7 dB.
I think you should call up Cambridge and see what they have to say, as previously suggested. I am still a little skittish because there are some amp circuits that just don't like 4 ohm loads, although that seemed to be a problem from years ago more than now.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 18th May 2004, 01:58 PM   #7
5th element is offline 5th element  United Kingdom
5th element's Avatar
I find it very hard to believe that a comercial amplifier would not contain any kind of SOAR protection circuitry or a thermal cutout. I would say that driving a 4 ohm load is not going to cause the amplifier any problems unless you really want to crank the volume control. As statd before 94 is very high sensativity, I dont think you will have any problems reaching high output levels.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Speaker impedance too low for amps!Hide this!Advertise here!
Impedance ratio and T-amps Sasquatch Class D 3 14th April 2013 07:44 PM
Op amps: output impedance and load resistance mudihan Chip Amps 36 28th October 2012 04:15 PM
Tube amps, power and speaker impedance Klimon Tubes / Valves 3 11th January 2007 08:32 AM
Hi-Fi amps....an impedance question rossco Multi-Way 4 25th March 2004 05:26 PM
High impedance out amps VS as low as possible. Brian Guralnick Solid State 57 31st October 2002 08:47 PM
