Hi !
I have looked at Avalon eidlon with the 11" but i get some very strange values when using the same size of the box (75 l) and the same Vents tuned to 19Hz as they do... Are they using a diffrent model of 11" or what ? Can you suggest a volume for my 11" ? Nominal rated power 150 W Nominal impedance 8 Frequency range 25-1000 Hz Sensivity 1W/1m 91 dB Resonance freq. TSP 21 Hz Qms 6,68 Qes 0,31 Qts 0,30 Vas 153 l DC resistance 5,2 LInear excursion 5 mm BL product 12,4 Tm Moving mass incl. air 67,3 g Effective piston area 366 cm² Dome material HEXACONE Voice coil inductivity 1,18 mH voice coil Ø 50 mm Former material Kapton Air gap heigt 8 mm Magnet Ø 134 mm /Magnus |
#2 |
I have looked at an avalon eidolon clone after reading Martin Colloms HiFi News review of them, In which he states " A low Q sealed box alignment is used, the reflex vent deliberately detuned to extend the extreme bass and more helpfully augment the systems low frequency dynamic range."
http://www.avalonacoustics.com/pdfs/eidolon_revu.pdf In using WinISD with the Eton TS parameters for a 75L enclosure around 19HZ does seems a good trade off for phase and group delay characteristics. This seems so over a range of Q. The measured -3dB point is around 36Hz which is in line with the calcs. For this size this seems a reasonable choice to me. What are your particular queries? |
| Enclosure Volume | Mat_89 | Subwoofers | 3 | 19th September 2006 10:27 AM |
| midbass enclosure volume | omni | Multi-Way | 1 | 2nd June 2006 02:47 PM |
| Enclosure Volume | sonu | Multi-Way | 12 | 14th May 2004 09:38 AM |
| Sub: Volume of Enclosure with Amp | bigkid | Multi-Way | 16 | 19th July 2003 06:12 AM |
| Enclosure Volume | r_s_dhar | Multi-Way | 16 | 13th August 2002 06:24 AM |
| Page generated in 0.05911 seconds (80.24% PHP - 19.76% MySQL) with 10 queries |
