Old 17th May 2004, 07:52 AM   #1
Monroe is offline Monroe  Canada
Cool Speaker Gaskets - Woofers & Tweeters (Odin Project)
Hi!
I'm just finishing up my SEAS Odin Mk3 project (an MTM ported design), and have run into an interesting problem: what to use for the driver gaskets?
I ordered the parts as a kit from Solen, and they didnt include anything for the purpose. I have some of those messy gasket-calk-roll stuff from parts express, left over from a previous project, but I don't want to use that stuff - I want to be able to remove the drivers cleanly - no messy stuff.
So: I assume that I need a gasket for both woofers and tweeter (right?) - and I want something solid. Is there a usual material / procedure? Any cautions / advice?
Thanks!
PS: I should be done the speakers very soon - I will post a full photo report on the whole construction in about a week! My first audiophileish speakers! I'm so excited!
Old 18th May 2004, 03:50 PM   #2
bUmP! For the love of god, BUMP!
Old 18th May 2004, 03:59 PM   #3
Send a message via AIM to jewilson
If you have a good flat mating surface for the drivers you don't need the gaskets. I you were doing a sealed box that a maybe.
If you cabinet has thin walls then you should consider using a gasket.
Jim W.
Old 18th May 2004, 04:08 PM   #4
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
My Thor TL kit from Madisound came with thin foam tape, which works great. I ordered a bunch more of it, and have been using it for all my speaker projects ever since.
Brian
Old 18th May 2004, 04:17 PM   #5
johnnyx is offline johnnyx  United Kingdom
Default re; gasket
I've used weather stripping, for sealing windows & doors to prevent draughts. It's thin foam, cheap and readily available. Try hardware or household stores especially in winter
Woofers, tweeters Vifa, PSB Peerless FS feke67 Swap Meet 0 10th May 2008 04:34 PM
6 Wayne J Dayton Home Theater Speaker kits (woofers, tweeters, xovers) wigginjs Swap Meet 0 27th February 2006 01:49 AM
Korean Woofers/Tweeters caratje Multi-Way 8 28th January 2005 01:44 PM
Matching effeciency between tweeters and woofers? RyanP3H Multi-Way 2 20th February 2004 05:05 PM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Page generated in 0.12797 seconds (73.17% PHP - 26.83% MySQL) with 10 queries
