Old 16th May 2004, 11:51 PM   #1
tom1356 is offline tom1356  United States
Default Latest incarnation of my open baffle/dipole speaker
It's a beyrllium ribbon tweeter, a boron/titanium 3" fullrange on a leather covered corian baffle, and three 12" graphite composite woffers. My goal was to try to get away with no equilization. It seems to be flat to about 40 hz. I will be playing around with crossover points till I'm old and grey it seems, but the sound right now is very satisfying. I need to do a finish on the W baffles, but I havn't decided how just yet.
Any sugestions?
My "cult-like" following is accepting applications.
Old 17th May 2004, 12:20 AM   #2
Ah, interesting design, to say the least.
Old 17th May 2004, 01:35 AM   #3
Bose(o) is offline Bose(o)  Canada
Very nice and welcome to the half-completed Open Baffle Club. Right now I have finished my mid-high panel in veneer with semi-dark stain-don't remember what colour. For low-end I have a single Illusion Audio LM-804, seems to do the trick with my budget. It resides in an H-baffle and is bare MDF. I will be finishing it in veneer and may try using rubbing oils or marine resin, still unsure. Anyway, looks to sound nice and hope everything works out!
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 17th May 2004, 04:35 AM   #4
Impressive.
Are you using passive crossovers by any chance? I'd be very interested in hearing about your strategy for matching levels and combatting dipole bass rolloff, if you're willing to share any information about that.
Old 17th May 2004, 04:37 AM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Everything that comes from Tom is impressive.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th May 2004, 09:32 PM   #6
Originally posted by HeatMiser
Impressive.
I am breaking all the rules. I use passive crossovers and one 8 watt SET 300b mono block amp per side. The tweeter is crossed at 12k 1st order. The mid is run full range with a home made 8 ohm silver wire non inductive resistor in series. The woofers are crossed at 150 hz Linkwitz-Riley 2 nd order.
You are to kind. I aspire to your standards.
Have you started your Halo's yet?
Old 17th May 2004, 10:34 PM   #7
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Tom,
With the 2nd order xover on the woofer, was it necessary to change its wiring polarity to integrate it with the full-range driver?
Everyone has a photographic memory. It's just that most are out of film.
Old 17th May 2004, 10:58 PM   #8
Originally posted by johninCR
Tom,
JohninCR
Yes the woffers are out of phase with the full range.
Old 17th May 2004, 11:10 PM   #9
Timn8ter's Avatar
Please tell the true story of the squiggly boards behind the speakers.
Old 17th May 2004, 11:41 PM   #10
I could tell you but then I'd have to...well you know.
They are copys of these.
http://www.enjoythemusic.com/superio...hallograph.htm
My open baffle dipole with Beyma TPL-150 StigErik Multi-Way 1196 18th May 2012 12:19 PM
My latest: Open baffle mid, Lambda TD12H, B&C 6md38, Peerless HDS dlneubec Multi-Way 15 1st January 2010 03:10 PM
Latest incarnation of music angel kt88 DC2100 Tubes / Valves 8 28th January 2009 11:35 PM
Open baffle/ dipole design help Infinity buff Multi-Way 3 12th April 2006 02:19 AM
Page generated in 0.09857 seconds (79.36% PHP - 20.64% MySQL) with 11 queries
