ARDA - Assisted Rectangular Driver Array
Old 3rd October 2004, 01:02 PM   #11
phase_accurate is offline phase_accurate
Try here:
http://patft.uspto.gov/netacgi/nph-P...&RS=PN/5802190
Charles
Old 3rd October 2004, 02:39 PM   #12
BillFitzmaurice is offline BillFitzmaurice  United States
Banned
Default Bessel vs Line arrays
Bessel arrays have never proven particularly successful, offering few benefits to justify their complexity. Line arrays work, and currently comprise better than 90% of very high end ($100k and up) pro-sound installations because they work far better than the cluster (rectangular) arrays they are replacing. Be it a Bose 901 or a 32 box pro-touring cluster array that design approach just doesn't work very well.
Old 3rd October 2004, 03:20 PM   #13
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
I've already done the 5 x 5 square bessel array and the 5 and 7 unit bessel bessel arrays, using the amplitude weighted approach. It's actually quite simple, just a wiring configuration. The link I had for it stopped working months ago.
It works perfectly for what it is intended and that is to make an array disperse like a point source. The problem is that imaging is lost. The sound is quite interesting in that with 2 speakers the image is just a wall of sound between the speakers.
If anyone has the book or even just the wiring diagrams, please post the info, as I'd like to try it again for use as a center channel. I think the 7 unit array mounted horizontally may make a perfect center channel for HT.
Everyone has a photographic memory. It's just that most are out of film.
Old 3rd October 2004, 06:57 PM   #14
AJ is offline AJ  United States
Default Just out of curiosity
Has anyone ever tried an array similiar to this? The red circles are tweeters.
I'm looking for ways to use all those 49 cent drivers I have.
Old 3rd October 2004, 10:54 PM   #15
Banned
That design would be a comb-filtering nightmare in both planes. With any vertical array you have to keep the individual drivers of the same frequency band all in the same vertical plane, mounted as tight as possible,
ARDA - Assisted Rectangular Driver ArrayHide this!Advertise here!
Line Array with PHY Driver jpetek Multi-Way 6 9th December 2012 02:35 PM
MCM Driver Sealed Array wrenchone Multi-Way 3 4th November 2008 03:48 AM
TMM driver array question Puppetnation Multi-Way 12 14th May 2008 07:03 AM
Possible budget line array driver? mpmarino Multi-Way 6 7th May 2007 02:03 AM
Jordan JXR6 driver array neil_kaye Full Range 1 21st September 2006 09:54 AM
