Old 15th May 2004, 04:06 PM   #1
Default Help on choosing an old Goodmans speakers
Need a lot of help!
Does anyone recommend a good old speakers by Goodmans?
Which any of these would someone recommend from ebay and why:
http://search-desc.ebay.co.uk/ws/sea...rched=2&sotr=2
Thank you!
Old 15th May 2004, 04:15 PM   #2
pinkmouse's Avatar
The HE1s are probably the only ones you could call classics, but even so are still beaten by other comparable competitors. But for around £75, you will certainly get good value
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th May 2004, 06:44 PM   #3
Thanks for your reply
So if i was to look for an old speaker (say 1970's to early 1980's) then i should be looking for a pair of speakers by Rogers or Tannoy?
Old 15th May 2004, 09:21 PM   #4
Previously: Kuei Yang Wang
ThorstenL's Avatar
Default Re: Help on choosing an old Goodmans speakers
Konnichiwa,
Originally posted by beta_sound
Need a lot of help!
I would recommend non of those in the search.
Goodmans was a huge company making OEM and Retail Speakers covering the range between cheap, nasty and awfull sounding (especially later items, post the early 1970's) and great. Due to the extreme width & breath of their range it is hard to say if an unknown Goodmans Speaker turns out great, acceptable or awful.
Sayonara
Old 16th May 2004, 08:47 PM   #5
planet10's Avatar
Of the Goodmans i've had thru here -- not a large sample set mind you -- the little Goodmans Maxims were the only ones worthy of keeing in their boxes.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th May 2004, 08:58 PM   #6
Things are a little cross threaded here, I'd forgotten about
the Maxim's, which are not bad for music, but are brilliant
near field monitors for studio use.
As stated in another thread the Dimension 8 is the only
other Goodmans of note - a semi line array design.
sreten.
small metal boxed goodmans speakers baggins Multi-Way 0 30th April 2006 12:00 PM
speakers choosing ulolin Car Audio 4 19th November 2005 11:27 PM
I have some Goodmans Mezzo SL speakers... Matttcattt Multi-Way 2 29th January 2004 03:30 AM
Choosing amplifier for PC speakers soundNERD Chip Amps 9 27th September 2003 02:10 AM
Opinions on Goodmans Speakers bm_mode Multi-Way 3 22nd March 2003 04:53 PM
Page generated in 0.09723 seconds (71.93% PHP - 28.07% MySQL) with 10 queries
