diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   6.5" Bass TL? (http://www.diyaudio.com/forums/multi-way/34086-6-5-bass-tl.html)
bhg41088 15th May 2004 12:56 AM
6.5" Bass TL?
I want to use 2 6.5 or 2 8" drivers for my HT. Anyone have a link to a really inexpensive (20$ or so) TL bass project with good, tested results? Think 2 of them will be enough?
bhg41088 15th May 2004 01:02 AM
I was thinking something along the lines of the Dayton Al 7", dayton 6.5 or the dayton 8". They are all under 20 each. I dont need to get massive loud, but i would like good low frequency responce. Down to 25 or so Hz.
454Casull 15th May 2004 01:46 AM
Let's see... you want to get down to 25Hz at a respectable level for less than $10 per driver, eh?
bhg41088 15th May 2004 05:47 AM
no, less than or a little more than 20 or a little more a driver. If you noticed, what i listen are 13-18 each.
sreten 15th May 2004 09:31 AM
Your goal sounds a little unrealistic, really depends on your
placement for proper use of room gain, and your lowest
room mode frequency, < 30Hz is certainly possible.
However I'd suggest building the Dayton D3
http://www.speakerbuilder.net/web_fi...D3/dayton3.htm
In these cabinets :
http://seas.no/thor.htm
:) sreten.
GM 16th May 2004 01:51 AM
2 Attachment(s)
No proven design, but you got me curious about the el cheapo 8" (295-310), so using PE's measurements I did a dual driver extended max flat alignment ML-TL (forget getting any useful output to 25-30Hz from a TL with this driver):
L = 59.78"
WxD = 98.854"^2 net
driver down 21.125"
4" dia. x 6.5" long vent near/at the bottom
0.2lbs/ft^3 stuffing density
all dims i.d. (inside)
Assuming the specs are ~accurate, this sims anechoically flat to ~31Hz with a ~25Hz F3, so some BSC will probably be required if not up against a wall or near a corner. If it's a bit boomy from room gain then some stuffing down by the vent and/or a longer vent will roll it off to suit.
GM
bhg41088 16th May 2004 03:38 AM
Whats the lowest audible frequency? I think 30 is fine, just making a small HT, so wanted to stick with it for the sub.
GM 16th May 2004 03:55 AM
Depends on how loud it is. 16Hz is audible in my room, but this is with four corner loaded 15". Unless you have a very large and/or open room, there should be enough room gain to push F3 to below 20Hz, enough for a small HT.
GM
Copyright 1999-2017 diyAudio
